 Post subject: Assistance Required For 7200.10 [ ST3250310AS ]
PostPosted: July 5th, 2016, 9:08
Hello Everyone ,
I Have a Case Its a Seagate 7200.10 Series Drive ,Model No is ST3250310AS ,Firmware 3.AHA .This Drive Had a Ce Log Error No 43,I Had No Clue That Another Tool DFL:SRP [ Not PC3K ] Has a Very Dangerous and Destructive Command To Handle Such Cases .It Takes The Drive To Terminal T> Mode And Uses a Command T4E To Clear Ce Logs ,In My Case This Process Did Not Complete Properly And Now i Have a Drive Thats In This Condition
Reset
4096k x 16 DRAM
NIGHTHAWKPLUS - 1_Disk S-1A 08-29-07_16:51
Buzz HM SFI
(P)SATA Reset
Not Interface Age!
INVALID Cert Disk Code - ROM Resident Revision Required: AHZ140
Command Inactive - No VALID Cert Code Detected
T>
PS : Can Someone Guide Me How To Solve this Its Been a While i Have Worked On Old Drives And The Only Tool i Had those Days Was Salvation DATA Seagate Doctor Which i do Not Use anymore .
 Post subject: Re: Assistance Required For 7200.10 [ ST3250310AS ]
PostPosted: July 5th, 2016, 9:32
T4E was a very bad moove, sorry to say it! :(
You have should to recover data by using LDR.
Did you do SA backup?
Can you restore modules from backup?
My firmware database:
PostPosted: July 5th, 2016, 9:37
T4E will rebuild cert table which often works but resets interface age also, without correct CERT code you cannot retutn interface age to native age 50.
You need to create custom loader from app code of your disk, then from here you need to load to RAM good cert code to allow good access.
T4E can work, but with bads in SA it will fail and brick HDD, also where CERT revision is different to ROM revision it wont allow restore to ATA age.
Maybe its possible to restore CERT with one from donor, but im not sure.
N50,22 is the command to return to age 50 but without correct CERT code you cannot retutn interface age to native age 50
PostPosted: July 5th, 2016, 13:24
have u try to load .. LDR
PostPosted: July 6th, 2016, 5:08
+1
Reset interface age is N50,,22
You missed a comma :)
Web: https://www.day1data.de
PostPosted: July 6th, 2016, 14:17
+1
:lol: :lol:
Thank you day1data, yes i missed to type the second comma.
Users browsing this forum: Majestic-12 [Bot] and 83 guests
