 Post subject: Is this HDDs compatible for Headswap
PostPosted: August 8th, 2016, 10:33
I attend to make headswap for this HDD, but I want your opinion about compatibility
Patient HDD
Model: HTS541075A9E680
P/N...: 0J26332
MLC..: DA5218
Donor HDD
P/N...: 0J26332
MLC..: DA5927
http://www.mediafire.com/view/kk9tk7czr ... WA0000.jpg
http://www.mediafire.com/view/0978ym6e7 ... WA0000.jpg
Expect, the Unexpected
 Post subject: Re: Is this HDDs compatible for Headswap
PostPosted: August 8th, 2016, 16:42
You'll need to check the head map, usually 3/4 heads are used in these as I recall.
PostPosted: August 9th, 2016, 0:33
exactly pcimage,,
I'm afraid to be different Headmap
PostPosted: August 9th, 2016, 17:48
I did it, now I retrive selective data
I found problem with PCB also!
PostPosted: August 9th, 2016, 19:02
I always replace those with a model HTS541010A9E680 so you're getting all possible heads. The MLC shoud still be the same and the part should be just one number off (E.G 0J26333). Here's one on ebay for a small fortune: http://www.ebay.com/itm/HTS541010A9E680 ... SwuAVWwrmp
Can probably find a cheaper one if you look harder.
PostPosted: August 10th, 2016, 1:32
Thanks alot data-medics
Ill be keep in mind next time
Users browsing this forum: Google [Bot] and 125 guests
