Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Rosewood
PostPosted: August 28th, 2017, 14:11
Hi to all! :mrgreen:
HDD ON
" No Clicking "
IS LOG
Boot 0x80M
Tech Unlock Handshake: 0x30A62C32
Reply:
ctrl+z
is log
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
CTRL+Z
is log
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
PrgF
(MC POR Duration): 00000007AC
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
ASCII Diag mode
F3 T>
ctrl+a
is log
Prod Desc: CheopsAM.1.0.SATA.Rosewood.Mule.Servo376.Rap30.AP1.4K + SMR Despo DFW
Package Version: RW07A8.SDM2.AA6973.SBM3
Serial #: W9318D7K
Changelist: 00997909
Model #: ST1000LM035-1RK172
Servo FW Rev: 8ACE
Heads: 2
PCBA SN: 0000K645KLPB
Default factory config: SD&D
Active config: SD&D
TotalHostWrites 00000000
NumberOfSegWrites 0000
TotalHPCBROs 00000000
TotalBWOs 00000000
MCMTWrites 00000000
Idle1Count 0000
MCSegmentUsed 0000
MCNodeUsed 00000000
is not id hdd, is not access sa.
help? :idea:
Нет ничего невозможного
 Post subject: Re: Rosewood
PostPosted: August 28th, 2017, 16:02
please look!
Rd Sys File: vol = 3, FID = 181, Copy = 000...
Receiving file FILE_3_181_0, length = 40960
COM transfer baud rate set to 115200
Wr Sys File: vol = 3, FID = 181...
Unsupported by FW!
Unsupported by FW!
Rd Sys File: vol = 3, FID = 093, Copy = 000...
Receiving file FILE_3_093_0, length = 8192
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F)
Wr Sys File: vol = 3, FID = 093...
Unsupported by FW!
Rd Sys File: vol = 3, FID = 093, Copy = 001...
Receiving file FILE_3_093_1, length = 8192
Unsupported by FW!
Executing user command.................. : Show Alt-List
ASCII Diag mode
F3 T>/
F3 T>
Error switching COM port baud rate
Unlock Tech Mode, drive prepared by utility : Ok
PostPosted: August 29th, 2017, 0:56
What seems to be the problem finally?
PostPosted: August 29th, 2017, 7:18
still do not know !! SA? :?:
PostPosted: August 31st, 2017, 0:38
Translator
DF :)
www.datatracksystem.net
PostPosted: August 31st, 2017, 0:58
darkforce1 wrote:
Translator
How do you come to this conclusion?
PostPosted: August 31st, 2017, 3:17
The drive has SA issue and can't initialize.
Did you try to Unlock tech mode?
if yes, try to refresh the drive ID.
HTH
PostPosted: August 31st, 2017, 5:43
Rosewood...... Another wonderful product from the SEAGATE factory .......
With each new product, new "scrap"..... (and being generous)
PostPosted: August 31st, 2017, 6:39
Sadly, most of us wouldn't have much work if it weren't for seagate.
PostPosted: August 31st, 2017, 6:56
Very soon we will have an equivalent 1TB from WD too, my guess the quality should have much much better than Seagate.
PostPosted: August 31st, 2017, 7:37
Well,
The Firmware in Rosewood is a Little Bit Different According To Ace .Stuff Like SMP Etc Is Still Not Implemented .The SA Structure of the WD HDD is Very Different should be easy to recover then this POS
PostPosted: August 31st, 2017, 7:50
Yes, more work, for sure!!!
But the work/cash ratio will be much lower (at least in my case)
And it is not a problem of the firmware lock, that only opens the doors to hell.......
PostPosted: August 31st, 2017, 8:18
HTH
Yes not ID!!
PostPosted: August 31st, 2017, 8:19
Masterclass wrote:
darkforce1 wrote:
Translator
Do not record anything on SA!
PostPosted: August 31st, 2017, 8:23
these drives are lacking the command to write sysfiles, so don't expect too much from pc3k.
PostPosted: August 31st, 2017, 8:38
:shock:
PostPosted: August 31st, 2017, 9:00
there is a way to write sysfiles with pc3k to these drives. :idea:
Data Recovery Pakistan
PostPosted: August 31st, 2017, 9:10
PostPosted: August 31st, 2017, 9:50
Is that so i Need To Ask TS Support From Ace again Is This is The Case
PostPosted: August 31st, 2017, 9:52
Wait TS Ace!!
Thanks!
Users browsing this forum: Himan and 46 guests
