Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: st1000lx015
PostPosted: January 7th, 2018, 22:59
Yep.....
Combined HD & flash storage, maybe 3-4 months old, good location, good cooling , not banged about.
Was working fine, no SMART errors a week ago test ,switched off computer came back 1 hr later turned it on and the drive is completely dead.
no spinup, no sound, swapped it to another machine , same result.
Quick look, nothing appears burned out, nothing hot
Any known issues with these drives?
Universal Declaration of Human Rights: Article 19
 Post subject: Re: st1000lx015
PostPosted: January 8th, 2018, 2:45
There are some, but qualified diagnostics is required.
PostPosted: January 8th, 2018, 4:48
If it's not spinning it could be a Power issue on the pcb or it could be sticktion...if you put Power on it, is there a faint beeping sound or buzzing or is it totaly dead?
http://www.rescue-it.se
PostPosted: January 8th, 2018, 4:54
Bad NAND flash?
To exclude a possible PCB fault, I could help with voltage test points, but I would need a detailed photo of the component side of the PCB.
PostPosted: January 9th, 2018, 6:14
Ok after 1 day of trying to find out WHY my cat chewed.....TTY board did not work.
The Drive, there is absolutely no sound what so ever, does not even get warm after 1 hr of power on.
Checking the 3 pin motor connector, there is no power or waveform on any of the connections, when metered or scoped
Serial connection I see this:
Boot 0x80M
DensityList:0x0000
LED:0x000000BD FAddr:0x00009C4C
..... continue as above
There is no response to ctrl-z ,ctrl-a etc.
Basically i just want to get it back on line so i can read the files.
PostPosted: January 9th, 2018, 7:05
I think it is Bad NAND flash. It is possible to recover the data. You should visit someone who know what to do.
Backup is Your best friend. Still learning English. Sorry for language bugs. My websites: Centrum Odzyskiwania Danych
PostPosted: January 9th, 2018, 19:02
Yep there is the kahuna fix which seems to apply to prior drives with flash.
I was thinking about a PCB replacement.
But I don't think there is a EEprom chip fitted. (I have a way to pull content from EEproms, without desoldering),
but this PCB does not appear to have a standard one,
(I may have a EEprom potential candidate...just looking at the PCB traces,but it means a new pogo pin Jig side connection not top hat)
It was just on the off chance one of you guys had run into the same shit and could save me some time.
I was also thinking about JTAG.
as regards the "locked" drive, i see that these drives can still have the user update the internal seagate firmware, some time ago i had thoughts of this as a side channel
PostPosted: January 9th, 2018, 19:06
Can you upload a detailed photo of the PCB?
PostPosted: January 9th, 2018, 20:19
PCB.
I suspect the EEprom is near the connector for the terminal, but with 6 pins instead of the usual 8
I'm also going to disable the CE line for the nand, this might cause the PCB to think the nand is not fitted , since it cannot read the chip ID nd this might bypass the code and put it into an init mode
PostPosted: January 10th, 2018, 1:27
viewtopic.php?f=1&t=35857
viewtopic.php?f=1&t=34804
PostPosted: January 10th, 2018, 5:47
Jez.....
looks same as
that pcb is serial eprom 25S81
MyPCB is 3A6K, is it the same serial eprom part or is there another supplier ?
ok looks like pogo pin time and a readup of the datasheets to see if I have a suitable emulator in my stable
and a big thanks for the amount of time you guys have saved me...fzabkar
Also the component marked "A1" is a TVS diode , not a fuse, it is clearly banded at one end (same as my pcb) and reads as a diode on a multitester.
PostPosted: January 10th, 2018, 15:01
3A6K is W25Q80BWBYIG.
    3A = W25Q80BWBYIG
    6 = year (2016)
    K = work week
W25Q80BWBYIG, Winbond, marking 3Axx, 8M-bit, 1.8V, serial flash memory, package WLBGA-8:
https://www.tvsat.com.pl/pdf/W/w25q80bw_win.pdf
http://www.srdzkj.com/pdf-1/W25Q80BW.pdf
PostPosted: January 10th, 2018, 22:54
Thanks again.....
I cannot believe that Seagate is using the likes of "winbond" as a parts supplier, their reliability is not upto par, we used to buy part from them.
The epoxy they used was hygroscopic & the spec of the parts changed depending on the humidity.....
I'm off to get a replacement drive lets see how it goes....
PostPosted: January 11th, 2018, 2:59
Are you able to find a firmware update at Seagate's Download Finder? It won't help you fix your problem, but the firmware modules may have some useful information. For example, it may tell us if the ROM architecture differs from regular F3 ROMs.
If you are so inclined, we could measure the onboard voltages for the benefit of others. I suspect that the 6-pin IC may be an LDO regulator. Perhaps disabling the NAND supply would achieve the same end as disabling CE?
PostPosted: January 11th, 2018, 4:01
What is the use of typing 100500 messages which are not in the least concern with the solution? If TS really needs data its better to ask who really CAN handle this drive. In fact, there are VERY few people around who can.
PostPosted: January 11th, 2018, 4:29
@"Masterclass", if you have something useful to add, then please do.
PostPosted: January 12th, 2018, 0:46
I did! In fact, my advice is much more useful than posting pseudo-useful pictures and "datasheets". Obviously, the drive has NAND troubles. Its features go deep to code and its really useless to check voltage, clean with duster or replacing DVI-VGA monitor cable. There is no any fw update for these drives and even if there were - it would be also useless.
PostPosted: January 12th, 2018, 2:54
Other Seagate SSHDs use an ST1L05CPU33R 3.3V LDO regulator to power the NAND flash. Its pinout looks very similar. Perhaps the NAND could be disabled by driving the regulator's EN pin low.
ST1L05CPU33R, ST Microelectronics, LDO regulator, 3.3V, 1.3A, marking 1L05C33, DFN6:
http://www.st.com/web/en/resource/techn ... 186925.pdf
PostPosted: January 12th, 2018, 5:55
Are you joking?
Take Kahuna drives for example (drives which are much more simple than Rosewood ones). If you know the field well, you might remember that the solution is far from hardware modifications. Why do you advice to do the things which 100% will not help? To make people spoil their drives?
PostPosted: January 12th, 2018, 8:43
How will disabling the NAND "spoil" the drive?
