 Post subject: st500dm002-1bd142 hp73
PostPosted: December 26th, 2018, 18:56
Hello
I have a st500dm002-1bd142 sn/z3tw3xw7 that will not spin up with the original PCB. I tried another pcb from a working hdd and it spins but is detected as wrong size 4.GB and will not show my data...if I put the ROM on another good pcb then it will not spin also .So i figured that the ROM may be corrupted.
I have attached the ROM dump if anyone can help me find what is wrong with the code in the ROM.
The pcb is the original one and the rom is the original one.
File comment: st500dm002-1bd142 dead
EN25F40_20181225_204243 - Copy.rar [138.58 KiB]
Downloaded 514 times
 Post subject: Re: st500dm002-1bd142 hp73
PostPosted: December 27th, 2018, 7:08
Full terminal output from original drive / pcb would helt a lot more.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 27th, 2018, 11:55
Original ROM has corrupt BOOT_FW in copy 0. Try this.
new_rom.zip [215.04 KiB]
Downloaded 478 times
PostPosted: December 27th, 2018, 14:58
@E123 could you explain how you determined this error and fixed it? I imported the "bad" ROM into PC3K and verified parts of the ROM are corrupt (error message when trying to "Show Information"). But, even after importing CAP+RAP+SAP+IAP to a donor ROM, it was still corrupt. Perhaps moving the Head Adaptives to a donor ROM could work, but I think you did something else. Just curious.
Thanks,
Brian
PostPosted: December 27th, 2018, 15:13
bcometa wrote:
@E123 could you explain how you determined this error ...
F3romExplorer :
http://www.hddoracle.com/viewtopic.php?f=22&t=2534
The first copy of the BOOT_FW segment (ID = 0x10) is located at 0x404D0 - 0x5F4CF.
Offset(h) 00       04       08       0C
00040000  D50D0000 D8040000 F0030000 400D0400  Õ...Ø...ð...@...
00040010  63736944 00003625 FFFFFFFF 20FFFFFF  csiD..6%ÿÿÿÿ ÿÿÿ
00040020  16380000 15400000 0E400200 10D00400  .8...@...@...Ð..
00040030  00D0F401 00000000 00000000 407F0000  .Ðô.........@...\
The second copy of the BOOT_FW segment (ID = 0x10) is located at 0x604D0 - 0x6F4CF.
00060000  D50D0000 D8040000 F0030000 400D0400  Õ...Ø...ð...@...
00060010  63736944 00003625 FFFFFFFF 20FFFFFF  csiD..6%ÿÿÿÿ ÿÿÿ
00060020  16380000 15400000 0E400200 10D00400  .8...@...@...Ð..
00060030  00D0F401 00000000 00000000 407F0000  .Ðô.........@...
Comparing these two segments reveals a difference in one bit.
PostPosted: December 27th, 2018, 15:41
THANK YOU fzabkar! I managed to figure it out and repair the ROM. :)
PostPosted: December 27th, 2018, 16:01
@E123 is the author of F3romExplorer. All credit should go to him.
PostPosted: December 27th, 2018, 16:22
Thanks to E123! Very cool tool to have!
PostPosted: December 27th, 2018, 18:03
Thank you E123 for your expertise and fzabkar for explaining.The hdd is now spinning and detectable in bios.
Would it have been possible to repair the Rom file by copying a BOOT_FW segment from another working HDD if both segments are corrupt.
PostPosted: December 29th, 2018, 15:20
Yes, but I would think that you would need to ensure that the code is compatible.
Users browsing this forum: Google [Bot] and 105 guests
