 Post subject: ST3000DM001 Spins Up, Not Seen in Bios
PostPosted: January 13th, 2021, 18:02
ST3000DM001 spins up, not seen in bios at boot. FW version is CC24, has not been updated. When connected externally via USB interface, it shows as an unrecognized device.
Connected to the drive via serial but only get the following. ctrl-Z does not seem to get me past this. I tried on another drive and was able to enter crtl-z to get to the prompt, so interface cable is ok.
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
Any ideas?
 Post subject: Re: ST3000DM001 Spins Up, Not Seen in Bios
PostPosted: January 13th, 2021, 21:21
Update, it took a while but I was able to get into the Terminal and got some additional detail, but it seems to be stuck repeating:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 15.566 secs
F3 2>U
LED:00000067 FAddr:003E01EE
Rst 0x40M
LED:00000067 FAddr:003E01EE - repeats
PostPosted: January 13th, 2021, 21:44
F3 T>
Package Version: GPG17D.CCD2.AX0851.CC24 , Package P/N: 100714019, Package Global ID: 00188399,
Package Build Date: 08/24/2012, Package Build Time: 12:53:59, Package CFW Version: GPG1.CCD2.00481239.00188399,
Package SFW1 Version: D7E5, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 08241253, CustomerRel: CC24, Changelist: 00481239, ProdType: GPG1.CCD2, Date: 08/24/2012, Time: 125359, UserId: 00188399
Servo FW Rev: D7E5
RAP FW Implementation Key: 16, Format Rev: 0004, Contents Rev: 71 01 07 00
TCG IV Version: n/a
PostPosted: January 14th, 2021, 8:14
Any hope for recovering data from this one? Any advice is greatly appreciated.
PostPosted: January 14th, 2021, 14:57
press ctrl-V, this will enable interface command echo on terminal, so we can see status register when you plug it to the pc.
So the order should be:
-connect terminal
-power drive up (without usb connection)
-press ctrl-r, then ctrl-v after SATA Reset appears, you should see something like EchoInterfaceCommands: On
-attach drive to pc through usb
post the log here.
PostPosted: January 14th, 2021, 16:53
-connect terminal
post the log here.
Thanks Pepe.
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
ASCII Online mode
ASCII Online mode
EchoInterfaceCmds: On
EchoBackgroundActivities: Off!!!!
(H) SATA Reset
The disk shows up in Disk Manager as invalid. (It was not showing up at all before)
I tried to activate it but got this:
PostPosted: January 14th, 2021, 17:43
It eventually disappeared from Disk Manager and went to USB device not recognized
(H) SATA Reset
(H) SATA Reset
(H) SATA Reset
(H) SATA Reset
(H) SATA Reset
(H) SATA Reset
(H) SATA Reset
(S) SATA Reset
(S) SATA Reset
(H) SATA Reset
PostPosted: January 14th, 2021, 18:39
do not initialize it, coz you can loose the partition table. It's odd it doesn't show any commands and that it disappears from DM.
why don't you attach it through sata?
PostPosted: January 14th, 2021, 21:06
I can try to connect it directly to a sata port on the motherboard.
PostPosted: January 21st, 2021, 9:14
I tried a few times, at first it was showing up in the diskmgr as uninitialized.
Currently its not showing.
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
(H) SATA Reset
ASCII Online mode
PowerState = IDLE1
PowerState = IDLE2
APM disabled by SPort
ASCII Online mode
HighPowerMode Status 0001 Req 0002
PowerState = IDLE2
ASCII Diag mode
F3 T>
ASCII Online mode
EchoInterfaceCmds: Off
EchoBackgroundActivities: On
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode Status 0001 Req 0027
Spin Down Complete
Elapsed Time 15.558 secs
F3 2>U
Spin Up Complete
Elapsed Time 7.284 secs
F3 2>
ASCII Online mode
PowerState = IDLE2
ASCII Diag mode
F3 T>
ASCII Online mode
ASCII Online mode
(H) SATA Reset
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
(H) SATA Reset
PostPosted: January 21st, 2021, 9:18
Spindown/Spinup give he LED errors again:
(H) SATA Reset
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 15.555 secs
F3 2>U
Rst 0x40M
Users browsing this forum: No registered users and 84 guests
cron
