 Post subject: WD "MyBook" 1TB HDD Bad Sectors Help
PostPosted: February 3rd, 2021, 7:19
Hi there,
We try to get data of an WD "MyBook" 1TB HDD.
What has been done so far?
- Attached with original WD MyBook Adapter
- Attached directly with SATA
- Attached with Delock Adapter
- Disk shows up in diskmanager
- Disk can not be initialized (CRC Problem)
- No Partition found. Not even a RAW partition
- Testdisk, photorec and DDRescue on Linux mint have no chance.
- WinHEX also only reads bad sectors.
- See Video of the behavior of the R/W Head in Disk here:
http://argient-designs.ch/hdd/hdd-problem.mp4
From 0:25-to infinity it is searching for data.
Is there anything we forgot to do? Or is this the end of the story?
Thank you very much for your help.
 Post subject: Re: WD "MyBook" 1TB HDD Bad Sectors Help
PostPosted: February 3rd, 2021, 14:30
Sorry but you should never power a disk without lid and you should never open a drive outside a clean environment. If you want to recover data, your only option is a Pro Data Lab.
PostPosted: February 3rd, 2021, 14:46
Was not first time and never had a problem for a look inside. If I had to do hardware stuff sure. At leat class 10.
Can't afford PC-3000. You know what i mean. Any chance in a lab?
PostPosted: February 4th, 2021, 9:05
We can try in a lab. I sent you a PM.
Users browsing this forum: Majestic-12 [Bot] and 69 guests
