 Post subject: I need LDR for ST380815AS.
PostPosted: March 3rd, 2021, 9:17
Firmware version: 3.CHF
I use MRTLAB.
Thanks.
 Post subject: Re: I need LDR for ST380815AS.
PostPosted: March 4th, 2021, 6:18
I have got it. Thanks.
ST380815AS-3.CHF-6RW0QF4Y-S3E-.082-E504-032707-DATA.rar [465.26 KiB]
Downloaded 433 times
PostPosted: March 4th, 2021, 10:02
I have the following error. Can anyone give me any ideas?
T>Reset
1024k x 16 DRAM
NHAWK - 1_Disk    S-3E   03-27-07_13:53
HM SFI
(P)Failed sys sect. write! Nwt Er 33 RdWr 13b44.00.0003
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 13b44.00.0003
Failed sys sect. write! Nwt Er 33 RdWr 13b46.00.0163
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 13b46.00.0163
PostPosted: March 4th, 2021, 16:47
I have experienced sometimes with this type of drives, i never solved with MRT ldr.
Instead, if i remember well, this type of issue i solved by doing hot swap, but you need same type of drive and same fw version as donor.
P.S.
Before doing hotswap i suggest to backup modules with sediv or STcom, because MRT doesn't even backup modules correctly from drives with F architecture.
My firmware database:
PostPosted: March 5th, 2021, 14:22
Thank you very much michael chiklis.
I will follow your advice and comment on the results.
Users browsing this forum: No registered users and 178 guests
