 Post subject: WD10EZEX-22BN5A0 inaccessible
PostPosted: March 11th, 2021, 5:56
Hi Guys, I have a problem with this WD10EZEX-22BN5A0 hdd. The hard drive is recognized correctly but is not accessible. I closed 02 applied patch for read errors and slow boot but nothing to do, I also manually loaded 02 and I can only read sector 0 if I try to read other sectors I get error. I have done head tests and they are ok, and I can read the whole SA and do full backup without errors. Do you have any suggestions ? Thank you
 Post subject: Re: WD10EZEX-22BN5A0 inaccessible
PostPosted: March 11th, 2021, 13:54
Does it report the correct capacity? Could it be a weird HPA problem?
PostPosted: March 11th, 2021, 14:28
Have you tried changing the heap map in ROM to select just one head and see if that head reads.
You will need to open DE task to test it fully.
PostPosted: March 12th, 2021, 14:00
I used the mrt test and it gives positive results, among other things if I try to read the entire firmware I can copy it completely without problems.
PostPosted: March 12th, 2021, 14:01
it reports the correct capacity or better known a small error but of only one byte I also manually set the right capacity but nothing has changed, I can only read sector 0
PostPosted: March 12th, 2021, 14:04
No that is not what I am saying.
Sometimes this trick works.
https://youtu.be/Xjl2RaPgLQ8
PostPosted: March 12th, 2021, 14:06
Check Module 31 and 47 firstly.
31 should not be empty
if 31 is empty then see if P list can be used to regen 31
Can you please report the status register state when you try to read data.
let us know :)
PS this is only when your LBA value / Capacity is rightly detecting
PostPosted: March 12th, 2021, 14:35
the translator not are empty, 47 is missing
PostPosted: March 12th, 2021, 14:38
Hi tks for suggest, I have tried to change head map in ram but dont work, this is the strange situation, to have control on the disk I need to close 02 but after load 02 from disk the capacity is 0 . If I open 02 and reboot the disk i see the real capacity but i read black like translator error.
PostPosted: March 12th, 2021, 14:41
Case looks HIGHLY solvable....as indicated it can be HPA issue. However, needs evaulation.
Should not take more than 10 mins to crack it any way.
For a 1TB drive the LBA count should be 1953525167 from 0.
try to set it in EDIT HDD ID in ram and do a soft reset. or try to set the HPA itself.
PostPosted: March 12th, 2021, 14:42
also, 47 is in rom...no faults there...don't bother..
PostPosted: March 12th, 2021, 14:46
It's not showing the right capacity. Likely HPA issue
PostPosted: March 12th, 2021, 14:47
+1
PostPosted: March 12th, 2021, 14:51
Yes adaptive data for head sorry
PostPosted: March 12th, 2021, 14:52
Can you upload module 02?
PostPosted: March 12th, 2021, 14:54
Open 02 and reboot == real capcity wont call for HPA issue
also you are in kernel as of now....
the issue looks elsewhere to me after reading this :D
PostPosted: March 12th, 2021, 14:57
I have write on first message, I see capacity but is inaccessible, but to manage the disk i need to close 02 and don't see capacity , whe i load 02 from disk capacity don't appair and is strange.
PostPosted: March 12th, 2021, 15:13
If it is a HPA issue, you can use HDAT2 or the following tool to restore full capacity:
https://www.datasynergy.co.uk/products/misc/atatool.aspx
BTW, your problem looks very similar to this one:
GigaByte BIOS bug results in loss of 1TB capacity:
http://www.hddoracle.com/viewtopic.php?f=59&t=150
PostPosted: March 12th, 2021, 15:15
Taks to all, I have solved
I have load 02 module from serial and now work and read with mrt utility option in DE
PostPosted: March 12th, 2021, 15:19
So it was a HPA problem ...
Users browsing this forum: No registered users and 58 guests
