 Post subject: How to copy ROM WD WD1600AAJS-08PSA0 ?
PostPosted: February 20th, 2023, 4:09
I have old WD 160Gb Sata WD1600AAJS-08PSA0, family: Sequoia.
Hdd totally dead, no spinning, no clicking.
I wonder that how to copy the ROM ?
There is no ROM IC, ROM storage in controller IC.
Hope somebody knows, it may some trick ? Or game is over.
Terminal/COM is no response, I use MRT.
 Post subject: Re: How to copy ROM WD WD1600AAJS-08PSA0 ?
PostPosted: February 20th, 2023, 8:27
If the preamp is ok, then you can hotswap it to find firmware version, then write the correct ROM based on the fw version to the donor pcb. Then, copy data.
PostPosted: February 21st, 2023, 3:07
If this is your PCB ...
https://dsmcz.com/prestashop/14260/pcb-2060-701444-004-rev-a-wd3200aaks-320gb-35-sata.jpg
... and if you want to check some voltage test points, measure the voltages at Q4 (near the SATA power connector) and C24 and D2 near the motor controller. These will be Vcore, Vio and Vneg (preamp).
PostPosted: February 21st, 2023, 4:14
Case closed [SOLVED]
Thank you so much for fzabkar, northwind, and Spildit, all you guys suggestion is works.
Best Regards
PostPosted: February 23rd, 2023, 5:16
So first place is swap embedded ROM QFP (supposed this 2nd chance), patient to donor hdd, it works, data saved.
Anyway , I replaced faulty Q4, TVS and R0 on patient hdd ( supposed this 1st chance), test the pcb, it works!
So in time being both donor and patient in working condition
Users browsing this forum: Google [Bot] and 111 guests
