 Post subject: WD Donor PCB query
PostPosted: April 26th, 2023, 5:21
I have got a WD 500AAJS (WD Caviar SE) hard disk. In PC3K it shows pcb short symptoms (all registers lit)
It is not spinning obviosuly pcb could be the issue. It has no physical rom present. I have more than 100 donor disks but none of them have similar pcb
(patient - 2060 -701477-002 Rev A) , all I have are 2060 -771640- XXXX) , will they compatible . Is there any way to repair PCB
 Post subject: Re: WD Donor PCB query
PostPosted: April 26th, 2023, 5:33
Couple of those caps don't look too healthy (76/37). Have you done the usual checks on the fuses & diodes and checked the voltages at the inductors.
PostPosted: April 26th, 2023, 7:10
Online
Instead of 701477 you can only use 701444
Mikippp
PostPosted: April 26th, 2023, 10:18
Thanks Lardman :good: :-D
Yes fuses and diodes are ok but I have missed capacitors. I will check.
PostPosted: April 26th, 2023, 10:20
Mikippp
Thanks Mikippp :good: :-D
I think I might be having at least one 701444 but how can I copy rom from patient to donor ?
PostPosted: April 26th, 2023, 12:35
Online
Try reading the ROM with BootCode.
If it fails, upload to the donor PCB ROM from the Tornado disk and rebuild the ROM based on SA modules.
Mikippp
PostPosted: April 27th, 2023, 1:11
Mikippp
Thanks Mikippp
PostPosted: April 27th, 2023, 1:14
Mikippp
hi Mikippp
I have similar case pending for exactly same model. Customer has given disk to a pc repair shop and in experimentation they have lost original pcb.
IS it possible to recover data using non native pcb or rom ? or regenerate rom using Tornado donor pcb
Thank you
PostPosted: April 27th, 2023, 2:25
yes, it is possible. With pc3k surely, not sure about the others, but i think it is also possible with a hex editor once you can access the fw and you know what to do with it.
PostPosted: April 28th, 2023, 1:37
Thanks a lot :good: , Your help will be useful for solving a pending case. I have PC3K but do not have 701444 PCB , where can I get model nos of compatible Tornado family disks and PCB nos. Will it be OK if Rev. A B C etc is mismatched
PostPosted: April 28th, 2023, 1:39
I have written a tool to regenerate the ROM from SA modules.
http://users.on.net/~fzabkar/FreeBasic_W32/WD/wdROMreg.bas
http://users.on.net/~fzabkar/FreeBasic_W32/WD/wdROMreg.exe
PostPosted: April 28th, 2023, 2:03
WO that's Great , using this tool I can extract rom from mere firmware without pc3K ?
Wonderful . Appreciate your skillsets fzabkar :good: :good: :good: :-D
PostPosted: April 28th, 2023, 3:15
Online
WD5000AAKS-00TMA0 2060-701477-001 REV A
WD5000AAKS-00YGA0 2060-701477-001 REV A
WD5000AAJS-00TKA0 2060-701477-001 REV A
WD5000AAJS-00YFA0 2060-701477-002 REV A
WD1600AAJS-00PSA0 2060-701444-002 REV A
Mikippp
PostPosted: April 29th, 2023, 2:41
Mikippp
Thank You so much :good: :-D
Users browsing this forum: No registered users and 86 guests
