 Post subject: WD Charger - Broken PCB
PostPosted: May 25th, 2023, 10:05
Hello guys, good day. I have here a complex case. Already had lots of Charger successful recovery here, but never got a broken original PCB.
How would you guys deal with a case like this, considering the original PCB encryption on those models?
Thank you for any answer
 Post subject: Re: WD Charger - Broken PCB
PostPosted: May 25th, 2023, 11:40
I would simply glue it with epoxy
PostPosted: May 25th, 2023, 13:26
pepe, Well... that is really an odd solution. Already got it done?
PostPosted: May 25th, 2023, 14:24
pepe, sorry for asking you that, but if hypothetically there was a missing fragment of the PCB, recovery would be impossible for this family?
Thank you so much for all your help.
PostPosted: May 25th, 2023, 16:22
Not really complex...unless you have heads compromised as well(due to fall?). Take a SATA Equivalent laptop HDD pcb....remove MCU of the patient and solder it on the sata pcb(ofcourse remove donor pcb mcu aswell)
Either do it the stencil way or via manual re-balling https://youtu.be/mpFPxUoHELg
it takes about 1hr 18 mins or so for manual re-balling 240balls if i got the count correct :)
easy pizy :D
PostPosted: May 25th, 2023, 18:13
He was joking ...
PostPosted: May 26th, 2023, 1:09
yeah, joking of course. I can't see any other solution than swapping the MCU.
PostPosted: May 26th, 2023, 2:58
Looks more like technician pry damage to me... just hope it wasn't inhouse.
PostPosted: May 26th, 2023, 7:47
I was just giving a benefit of doubt.
It's a mean industry where people try to monopolize over data... "None! if not me" is the concept. Life goes on.
PostPosted: May 26th, 2023, 8:31
pepe, fzabkar, Sorry guys.. lots going on here and I'm not used to this.
Thank you all so much for all your insertions. I'll be training hard with irrelevant similar drives before offering this to my customers.
Thanks a lot.
PostPosted: May 26th, 2023, 11:41
Customer sent me this way, saying that one employee that works for him had a psychotic break and did this damage
PostPosted: May 26th, 2023, 13:34
Thanks a lot.
yes sir...practice atleast 3 - 4 times....its fun
cheers
PostPosted: May 29th, 2023, 12:38
Thanks a lot.
cheers
Sin ,
Thats Too Many Balls :lol: ,Use a Stencil Buddy
PostPosted: May 30th, 2023, 10:20
stencil or no stencil. Be like Rambo :)
Users browsing this forum: No registered users and 76 guests
