 Post subject: WD Red Pro 6TB (WDC WD6002FFWX) ATA Locked (unlock?)
PostPosted: October 6th, 2023, 2:31
i got 3 Identical WD Red Pro 6TB SAS Drives (WDC WD6002FFWX) that got ATA locked within a security erase by a Friend.
Scenario:
The Drives came out of a Storage System and while Secure Erasing
(hdparm --user-master m --security-erase NULL /dev/sda)
the three disks, the Server doing it died mid way, so the Secure Erase probably havent finished at that point!
Now i got these Disks to use and Wonder if its possible to Unlock them and get them Usable again?
I tried unlocking them by using these master passwords i found on the internet, and ofc also NULL or (32 spaces).
hdparm --user-master m --security-erase WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCW /dev/sda
hdparm --user-master m --security-erase WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD /dev/sda
All result in an:
hdparm --user-master m --security-erase-enhanced NULL /dev/sda
security_password: ""
/dev/sda:
Issuing SECURITY_ERASE command, password="", user=master
SECURITY_ERASE: Input/output error
This is the Info of the Drives (all are identical):
/dev/sda:
ATA device, with non-removable media
        Model Number:       WDC WD6002FFWX-68TZ4N0
        Serial Number:      XXX
        Firmware Revision:  83.H0A83
        Transport:          Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0; Revision: ATA8-AST T13 Project D1697 Revision 0b
Standards:
        Used: unknown (minor revision code 0x0029)
        Supported: 9 8 7 6 5
        Likely used: 9
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:    16514064
        LBA    user addressable sectors:   268435455
        LBA48  user addressable sectors: 11721045168
        Logical  Sector size:                   512 bytes
        Physical Sector size:                  4096 bytes
        Logical Sector-0 offset:                  0 bytes
        device size with M = 1024*1024:     5723166 MBytes
        device size with M = 1000*1000:     6001175 MBytes (6001 GB)
        cache/buffer size  = unknown
        Form Factor: 3.5 inch
        Nominal Media Rotation Rate: 7200
Capabilities:
        LBA, IORDY(can be disabled)
        Queue depth: 32
        Standby timer values: spec'd by Standard, no device specific minimum
        R/W multiple sector transfer: Max = 16  Current = 0
        Advanced power management level: 254
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
           *    Security Mode feature set
           *    Power Management feature set
           *    Write cache
           *    Look-ahead
           *    Host Protected Area feature set
           *    WRITE_BUFFER command
           *    READ_BUFFER command
           *    NOP cmd
           *    DOWNLOAD_MICROCODE
           *    Advanced Power Management feature set
                Power-Up In Standby feature set
           *    SET_FEATURES required to spinup after power up
                SET_MAX security extension
           *    48-bit Address feature set
           *    Device Configuration Overlay feature set
           *    Mandatory FLUSH_CACHE
           *    FLUSH_CACHE_EXT
           *    SMART error logging
           *    SMART self-test
           *    Media Card Pass-Through
           *    General Purpose Logging feature set
           *    WRITE_{DMA|MULTIPLE}_FUA_EXT
           *    64-bit World wide name
           *    URG for READ_STREAM[_DMA]_EXT
           *    URG for WRITE_STREAM[_DMA]_EXT
           *    WRITE_UNCORRECTABLE_EXT command
           *    {READ,WRITE}_DMA_EXT_GPL commands
           *    Segmented DOWNLOAD_MICROCODE
                unknown 119[6]
                unknown 119[7]
           *    Gen1 signaling speed (1.5Gb/s)
           *    Gen2 signaling speed (3.0Gb/s)
           *    Gen3 signaling speed (6.0Gb/s)
           *    Native Command Queueing (NCQ)
           *    Host-initiated interface power management
           *    Phy event counters
           *    NCQ priority information
           *    READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
                Non-Zero buffer offsets in DMA Setup FIS
           *    DMA Setup Auto-Activate optimization
                Device-initiated interface power management
                In-order data delivery
           *    Software settings preservation
                unknown 78[7]
                unknown 78[10]
                unknown 78[11]
           *    SMART Command Transport (SCT) feature set
           *    SCT Write Same (AC2)
           *    SCT Error Recovery Control (AC3)
           *    SCT Features Control (AC4)
           *    SCT Data Tables (AC5)
           *    SANITIZE feature set
           *    OVERWRITE_EXT command
           *    Extended number of user addressable sectors
           *    WRITE BUFFER DMA command
           *    READ BUFFER DMA command
Security:
        Master password revision code = 65534
                supported
                enabled
                locked
        not     frozen
        not     expired: security count
        not     supported: enhanced erase
        Security level high
        640min for SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5000XXXXX
        NAA             : 5
        IEEE OUI        : 000cca
        Unique ID       : 255cxxxxx
Checksum: correct
So he told me he used "NULL" as Password for secure-erase i dont have further info about that.
Is there any chance to get these Disks usable again with reasonable effort?
nade
 Post subject: Re: WD Red Pro 6TB (WDC WD6002FFWX) ATA Locked (unlock?)
PostPosted: October 6th, 2023, 6:21
As additional Info:
The Disks are Currently in a HP DL 380p g8 connected over the Backplane which is Connected to an Dell Perc H200 with SAS2008-IT Firmware.
If thats relevant.
PostPosted: October 6th, 2023, 9:12
Looks like your drives are WD-HGST. If such drive can't read service area, it looks like security-locked. Modelname/firmware version/maxLBA store in SPI flash. Usually, in this case, only a few smart-attributes are available with unrealistic values.
PostPosted: October 6th, 2023, 13:47
IIUC, if the server's PSU died rather than the drive, the drive should automatically resume and complete the secure erase when power is restored. Or am I misunderstanding something?
PostPosted: October 6th, 2023, 14:27
Hi, Frank. I talking about there is no any "secure lock" really. If there is no HDA's answer for PSU's request, drive still stay in maximum security stage. (We can see it as "security lock"). I think, if TS will connect PCB only (without HDA), he can see the same picture as now.
Users browsing this forum: Google [Bot] and 47 guests
