 Post subject: doubt bios, firmware and smart
PostPosted: August 26th, 2024, 19:30
what chips in PCB HDD 2.5" or 3.5" store BIOS and firmware and SMART? are 3 chips for 3 files? what type of chip use for tree?
 Post subject: Re: doubt bios, firmware and smart
PostPosted: August 27th, 2024, 0:08
SMART data is typically located on the platters in the FW (SA).
PostPosted: August 27th, 2024, 5:21
1) FW (SA)????
2) what chips in PCB HDD 2.5" or 3.5" store BIOS and firmware
PostPosted: August 27th, 2024, 11:00
You could consider change username to doubt-a-lot.
PostPosted: August 27th, 2024, 20:14
sonicmario wrote:
1) FW (SA)????
For the record, I am convinced you're a bot.
FW = Firmware.
SA = Service Area (the location on the platters that stores firmware)
There is usually no "chip" that holds firmware; there are boot loaders.
The only exception to this rule is Hitachi (well, the old "Hitachi"); but that's a loaded gun question and is model / era dependant.
PostPosted: August 27th, 2024, 20:16
hdd 2.5 and 3.5" not use any memory chip eeeprom or flash for store firmware/bios?
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 51 guests
