 Post subject: WD5000AAKX-60U6AA0 Click twice then spins down
PostPosted: September 18th, 2024, 3:21
I got a drive 500GB WD. That from the beginning was clicking twice then spins down. Upon inspection the PCB, the ROM everything seems fine. So i came to conclusions that it is the heads
Got a matching donor, checked the platters and swapped heads. The drive still Clicked twice then spins down
I have tried uploading LDR, tried hot swapping but nothing worked.
Can anyone help me out?? Any suggestions is welcomed??
Thanks everyone!
Family:................................. : Tahoe XL
Techno mode key......................... : Ok
HDD Status sector....................... : Ok
RAM:
System controller (SoC)................. : 88i9045B0 0x(63B0)
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 82 104
SA regions address...................... : by default
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA SPT.................................. : 1290
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 05.30G
Module 4F F/W version................... : 00050030
Overlay F/W version..................... : 05.30G
Servo F/W version....................... : 0A.22
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Relocations............................. : 0 (0)
Read ROM DCM............................ : Ok
Power up log reading.................... : Ok
Power up load dir data.................. : No
Power up load permovl................... : No
Power up load CFG data.................. : No
NN | Step |     Time |    Flags | Info | Description
12 | 710A |    12 ms |      501 | 2093 | SET_SOC_POWER_MODE(Unknown error code: 2093)
15 |  405 | 5 575 ms | 2000083A | 5443 | ACTUATOR_INIT(SERVO ERROR CODE BASE SvirActPdFail)
20 | 710A | 5 575 ms |      501 | 2093 | SET_SOC_POWER_MODE(Unknown error code: 2093)
28 |  419 | 5 576 ms | 2000083A | 5480 | CAL_RRO_USER_ZONE(SERVO ERROR CODE BASE SvirCalRRO Hd0)
Service area:
SA dir reading (ID)..................... : Module ID 01 reading error Device Error Detected: "DISK SERVO ACTUATOR AI FATAL ERROR"
SA dir reading (ABA/CHS)................ : Module 01 reading error: ABA 82 104 C:1(1) reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Module ID 02 reading error Device Error Detected: "FM ERR NOT FOUND IN DIR"
DCM in module 47........................ : N5
DCM in module 0A........................ : |B|DN5SDAS
DCM in module 02........................ :
 Post subject: Re: WD5000AAKX-60U6AA0 Click twice then spins down
PostPosted: September 18th, 2024, 8:03
Did you try head mapping? may be 0 or 1 ,any platter damaged?
Data Recovery, Remote support & Training https://disksolution.com.pk/
PostPosted: September 18th, 2024, 9:35
yes. i've tried head mapping still double clicks and spins down. I checked the platters. No visual damage.
PostPosted: September 18th, 2024, 11:41
likely heads are gone...
Data Recovery Pakistan
PostPosted: September 18th, 2024, 22:24
i checked the heads. they are perfectly fine. swapped them back to donor. still works
PostPosted: September 19th, 2024, 7:06
did u rule out PCB, did you test patient heads in donor ?
PostPosted: September 19th, 2024, 21:55
I did rule out the PCB, but i haven't tested patient heads in donor
