 Post subject: Pinout of the 12 pin connector WD5000BMVW-11AMCS0 HDD
PostPosted: November 15th, 2024, 13:14
the SATA connector on my 2010 Western Digital WD5000BMVW-11AMCS0 HDD has de-soldered from the controller board.
Before I try to re-solder it (not an easy task), could you please tell me if I can save the data through in 12 pin connector located to the left of the SATA connector. I have searched for the function and pinout of this connector on the internet but found nothing.
Could you please help me?
Thank you
Alberto
 Post subject: Re: Pinout of the 12 pin connector WD5000BMVW-11AMCS0 HDD
PostPosted: November 16th, 2024, 11:23
- this is drive with USB connection, not sata
- that 12pin header is not for data transfer. there is a serial port thru which it is possible to access the data using special tools, but you don't want to do this.
you have 3 options:
- contact a dr pro who can deal with this problem reliably
- repair the orig pcb by soldering the usb connector back (requires some skills, and expertise)
- get a donor pcb and move U12 over
If you never used any soldering equipment, i don't recommend to DIY.
PostPosted: November 17th, 2024, 4:27
Thank you very much Pepe for your reply.
I will try with your 2nd option.
Alberto
Users browsing this forum: Google [Bot] and 62 guests
