 Post subject: Seagate ST31000340NS
PostPosted: March 30th, 2025, 18:19
The BIOS and system see the disk, but it can't be read. What can I try to do at home?
 Post subject: Re: Seagate ST31000340NS
PostPosted: March 30th, 2025, 20:29
The Seagate drives from this era were not exactly known for being the most reliable. The Barracuda ES.2 is the enterprise counterpart to the Barracuda 7200.11.
PostPosted: March 30th, 2025, 21:58
So, can't access to restore files? Trash?
PostPosted: March 31st, 2025, 5:32
If the data is not so important that you need to contact a DR specialist...
We buy a USB-TTL adapter, make a power switch for the HDD, and look at the startup log in the terminal.
And mounting a sick HDD in Windows is a bad omen... :)
Molex --------- Double switch ---------------- SATA Power
+5V ----------- swith -------------------- Red
+12V ---------- swith -------------------- Yellow
GND ---------------------------------------- Black
