 Post subject: ST500DM002
PostPosted: October 31st, 2026, 8:12
Drive in topic stays busy without terminal access (Even with shorting read channel).
Terminal output:
Boot 0x20M
SpinUp
Trans
Rst 0x20M Thermistor Temp 001A
PreampFaultStatus = 00C0
SIM Error 1002 LBA 0000000000045D8C FD FCFFF3FF
RW Error 44440080
SIM Error 1002 LBA 00000000000BFE11 FD FCFFF3FF
RW Error 44440080
2Sync:01 0E
2Sync:01 0E
2Sync:01 0E
(P) SATA Reset
SIM Error 1002 LBA 000000000003E179 FD FC38B30A
RW Error 44440080
SimErrorCode = 00001002, RWErrorCode = 44440080
RW Error 44440080
The Registry is corrupt.
LED:0x000000BD FAddr:0x00006454
Preamplifier really damaged ?
HSA replacement required?
Any suggestions?
Thanks in advance.
 Post subject: Re: ST500DM002
PostPosted: October 31st, 2026, 9:21
Head replaced
Drive cloning.
PostPosted: October 31st, 2026, 10:13
I'm assuming that the preamp reports the temperature (0x1A = 26C), so I'm wondering what kind of preamp fault would allow it to remain partly operational.
PostPosted: October 31st, 2026, 12:58
I beleive this is not the correct value, also there was a clear noise coming from the head at every (PreampFaultStatus = 00C0) indicates that the head was very weak to operate normally.
PostPosted: October 31st, 2026, 14:18
It's too late now, but you could have warmed up the preamp with a hair dryer and checked for a change in the reported temperature.
PostPosted: October 31st, 2026, 14:47
It's not too late, defective head still available.
After cloning complete I can reassemble the defective head and do the experiment and post the results.
PostPosted: November 1st, 2026, 7:20
Here the difference :
Boot 0x40M
SpinUp
Trans
Rst 0x40M Thermistor Temp 001D
(29C instead of 26 after some heat applied)
PostPosted: November 1st, 2026, 8:23
If you feel inclined to experiment, maybe you could cut off one head and see if the fault status changes.
PostPosted: November 1st, 2026, 8:47
The drive has only one head.
Users browsing this forum: No registered users and 40 guests
