 Post subject: MHDD Disk Sector Errors
PostPosted: February 11th, 2006, 20:58
I have been trying to check out a disk I've connected to a USB port. I haven't used the disk in a while, but it seems to be mostly OK according to Windows. However, to be safe, I wanted to check the disk out with some diagnostic and repair software.
After running MHDD, checking the log, and reading some information from posts on here, I have discovered that MHDD apparently hasn't read any of the blocks on the disk, apparently viewing them ALL as bad/unreadable.
I'm including here an example of the log report from MHDD:
þ Error in block 0; LBA: 4294967295
þ LBA Timeout: 0
When HDDscan was run through Windows, however, it only had problems with a relative handful of blocks, which had read times of >500ms.
Is there anything I need to do in MHDD to make the disk more accessable to it? If not, is there anything I can run through Windows that will allow me to mark/hide the problem blocks found by HDDscan so Windows doesn't use them?
Thanks for any help you can provide.
PostPosted: February 11th, 2006, 22:59
Did you run MHDD under MS-DOS?
Please provide first 50 lines of the log.
Dmitry
PostPosted: February 11th, 2006, 23:24
Well, it was either MS-DOS, or a good imitation.
First 50 lines? OK
11.02.2006 16:02:29
11.02.2006 16:02:29
11.02.2006 16:02:29 | MHDD 4.6 (c) Dmitry Postrigan | FREEWARE
11.02.2006 16:02:29 Changing mode to: IDE
11.02.2006 16:02:35 Changing mode to: SCSI
11.02.2006 16:02:35 Device selected: 6
11.02.2006 16:02:39
11.02.2006 16:02:39 MHDD>SCAN
11.02.2006 16:02:39 Maxtor 3 3073H3
11.02.2006 16:02:39 Capacity: 60032447
11.02.2006 16:02:42 Scan started
11.02.2006 16:02:42 MODE: SCSI
11.02.2006 16:02:42 1 block = 255 units (130560 bytes)
11.02.2006 16:02:42 Device: Maxtor 3 3073H3
11.02.2006 16:02:42 F/W:
11.02.2006 16:02:42 SN:
11.02.2006 16:02:42 -------------------------------
11.02.2006 16:02:42 Lap : 1
11.02.2006 16:02:42 LBA scan: 0 to 60032446
11.02.2006 16:02:43 þ Error in block 0; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 0
11.02.2006 16:02:43 þ Error in block 255; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 255
11.02.2006 16:02:43 þ Error in block 510; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 510
11.02.2006 16:02:43 þ Error in block 765; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 765
11.02.2006 16:02:43 þ Error in block 1020; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 1020
11.02.2006 16:02:43 þ Error in block 1275; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 1275
11.02.2006 16:02:43 þ Error in block 1530; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 1530
11.02.2006 16:02:43 þ Error in block 1785; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 1785
11.02.2006 16:02:43 þ Error in block 2040; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 2040
11.02.2006 16:02:43 þ Error in block 2295; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 2295
11.02.2006 16:02:43 þ Error in block 2550; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 2550
11.02.2006 16:02:43 þ Error in block 2805; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 2805
11.02.2006 16:02:43 þ Error in block 3060; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 3060
11.02.2006 16:02:43 þ Error in block 3315; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 3315
11.02.2006 16:02:43 þ Error in block 3570; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 3570
11.02.2006 16:02:43 þ Error in block 3825; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 3825
11.02.2006 16:02:43 þ Error in block 4080; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 4080
11.02.2006 16:02:43 þ Error in block 4335; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 4335
11.02.2006 16:02:43 þ Error in block 4590; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 4590
11.02.2006 16:02:43 þ Error in block 4845; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 4845
11.02.2006 16:02:43 þ Error in block 5100; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 5100
11.02.2006 16:02:43 þ Error in block 5355; LBA: 4294967295
11.02.2006 16:02:43 þ LBA Timeout: 5355
That should be at least 50. I don't know if, or why, you'll need the timestamps, but I'm leaving them in, just in case.
PostPosted: February 12th, 2006, 15:02
You have to figure out if it was dos. :lol: The only reason why could you see this is if you ran mhdd under windows.
And I would recommend you to remove the drive from the USB enclosure and attach it to the IDE.
To fix "long reads", you will have to erase the whole drive. I think you can use HDDScan to do this.
Dmitry
PostPosted: February 12th, 2006, 16:57
Sounds like there's nothing I can do, then, since I can't connect it to an IDE. If that's the case, thanks anyway. It's not like I was planning to use it for anything important, just more convienent access to some music files, all of which would be backed up to begin with. Since Windows can read it, there's no reason I can't still do it, I guess.
As for the DOS question, it was whatever was included in the Magic_Boot_Disk_ISO_V2.0.zip file. The OS identification goes by too quickly for me to see it.
Well, thanks again for the help. I'll try erasing the drive and seeing if it will help.
PostPosted: February 12th, 2006, 20:17
Yep... That was pure dos (comes with magic boot disk).
Erasing should help.
Dmitry
Users browsing this forum: No registered users and 61 guests
