 Post subject: Newbie need help - Maxtor DiamondMax VL40 #33073H3 - Proxima
PostPosted: July 7th, 2007, 0:24
I have a 2000 manufactured Maxtor DiamondMax VL 40 (model #33073H3) drive that is malfunctioning. In the BIOS it now gets recognized as Maxtor Proxima - also size is 10GB instead of original 30GB. It does not boot up. I put it as a slave drive on second computer and it is still Proxima in that computer also (and I get a drive failure message). Thirdly, I put it in a HD enclosure and set it up as a USB on another computer and it is also Maxtor Proxima.
I need to recover some of the data from it. From doing some research, I understand that it is a firmware malfunction. Where do I go from here? I was able to find a file that has a loader D215_yah814yz.ldr and A1.ram and bunch of rpm files (also some smb files). I am not sure how this works or how to use it.
Can you guys please help? Thanks very much in advance.
 Post subject:
PostPosted: July 7th, 2007, 1:08
Hi Ajit
You need PC3000 to repair drive. If data is critical then go to any Data recovery company. don't do it by your self
DF
 Post subject:
PostPosted: July 7th, 2007, 5:33
Yep, impossible with correct tools.
PC3000 or Salvationdata.
 Post subject: cost for PC3000 or Salvation data?
PostPosted: July 7th, 2007, 10:40
What is the cost for PC3000 and/or Salvation data? I am afraid the recovery company will charge arm and a leg (and than some)...
 Post subject:
PostPosted: July 7th, 2007, 16:56
AFF repair station would be quite cheaper alternate .
 Post subject:
PostPosted: July 8th, 2007, 5:10
Hi Ajit ,
If You Are Near Indore Contact Darkforce .If Near Chandigarh Tell Me .If Somewhere Else [ No Idea ]
 Post subject: In the USA
PostPosted: July 9th, 2007, 11:03
I am in the USA. Who can I contact in the USA for fixing my hard disk (or at least recovering my data)? :cry:
 Post subject:
PostPosted: July 9th, 2007, 23:26
Hi There ,
Some old people who know someone should please help the gentlemen .
 Post subject: AFF Repair Station and HDD Repair 2.0 will not work
PostPosted: July 10th, 2007, 21:47
- AFF Repair Station said their software will not work since firmware area appears to be damaged (or internal disk problem).
- HDD Repair 2.0 appears only to support Maxtor 541DX (I have diamondmax VL 40 - 33073H3 model number)
- PC3000, Salvation and HRT are too expensive for just one drive as Spildit said.
- Any other ideas (Amardir and Spildit are willing to help but too far from the USA)?
 Post subject:
PostPosted: July 10th, 2007, 22:19
I suggest you buy one HDD tool for your Maxtor. For Example, our new windows version --HD Doctor For Maxtor~ :D
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
 Post subject: Re: AFF Repair Station and HDD Repair 2.0 will not work
PostPosted: July 10th, 2007, 23:03
Check your PM.
 Post subject: Amarbir - please check your Private Message
PostPosted: July 12th, 2007, 11:52
Thanks.
 Post subject:
PostPosted: July 12th, 2007, 15:07
Hi Mates ,
PM Sent Issue Solved or Unsolved .And If Solved Share And Enlightened The World
 Post subject:
PostPosted: July 12th, 2007, 15:53
hdd repair works on all dsp and poker maxtor drives .
 Post subject: Not Solved Yet...
PostPosted: July 12th, 2007, 16:44
All - The private message by Starling did not solve the problem.
Amarbir - please check your private message.
rameez - are you saying that HDD repair 2.0 should work on my 33073H3 (maxtor 30GB) hard drive? I am willing to try it but I thought it will not work since HDD Repair 2.0 said that it only support 541DX. Let me know.
Thanks.
Users browsing this forum: Bing [Bot], Google [Bot] and 108 guests
