 Post subject: FAT copies are not identical
PostPosted: September 27th, 2006, 12:32
Hello Friends,
I have seagate U series 5, model ST320413A; FW : 3.57, the problem is FAT copies are not identical, maybe 1st FAT is broken.
If I check with Norton Partition Magic 8.05 appear error message : partition table error 108 found MBR bad, critical 501 cross-linked file were found.
I try to repair this problem with Testdisk, Diskpatch, victoria, Check FW is oke, but the problem is the same.
How to repair this problem, please.
Thanks very much
PostPosted: September 27th, 2006, 14:23
if U have important data on this partition, save it to a safe place (maybe U will need a logical recovery program). U have to choose a method that does not write to the disk at all, preferably with an option to select which FAT to use.
After saving I would recommend formatting the partition and copy back the needed data.
Trying to repair the damage may lead to loss of important files.
regards,
PostPosted: September 28th, 2006, 7:18
Thanks Pepe
I don`t need the data, I will repair HDD and use it.
I do :
1. erase with victoria, the problem is same
2. zero fill and LLF with disk manager, the problem is same
3. dell/refresh mbr with testdisk and disk patch, the problem is same
What can I do to solved the problem ?
PostPosted: September 28th, 2006, 11:45
maybe cable or connector problem. :?:
try it in another computer
PostPosted: September 28th, 2006, 21:00
The problem is same, I have soft WinHex, Can this soft solve this problem ?
PostPosted: September 30th, 2006, 10:58
check terminal log
Users browsing this forum: No registered users and 84 guests
