 Post subject: problem recovering damaged sector 0
PostPosted: October 28th, 2006, 18:30
Hello everyone,
I am having some problems with a Seagate 2.5" HD.
Although I can detect it in the BIOS, it will fail in post.
The drive has allot of bad sectors and BIOS can't read smart.
I believe my main problem is that sector 0 can not be read.
I have tried several different tools to recover sector 0, but nothing seams to work. I have tried to format the sector and I have also tried to add the sector to the defect list. But evertime I run a scan the sector still shows up as Bad. Here is my log.
7.05.2001  10:49:23   MHDD>ID
7.05.2001  10:49:31   ST9100823A  LBA: 195,371,568
7.05.2001  10:49:31   SN: 3LG191VV  FW: 8.03
7.05.2001  10:49:34
7.05.2001  10:49:34   MHDD>SCAN
7.05.2001  10:49:41   ST9100823A  LBA: 195,371,568
7.05.2001  10:49:41   SN: 3LG191VV  FW: 8.03
7.05.2001  10:49:43   Scan started
7.05.2001  10:49:43   MODE: IDE
7.05.2001  10:49:43   Device: ST9100823A
7.05.2001  10:49:43   F/W: 8.03
7.05.2001  10:49:43   SN: 3LG191VV
7.05.2001  10:49:43   -------------------------------
7.05.2001  10:49:43   Lap : 1
7.05.2001  10:49:43   LBA scan: 0 to 195371567
7.05.2001  10:49:52   þ LBA Warning: 0
7.05.2001  10:50:20   þ LBA Warning: 1992570
7.05.2001  10:50:22   þ LBA warning: 1994355
7.05.2001  10:50:23   þ LBA warning: 1995375
7.05.2001  10:50:24   þ LBA warning: 1995630
7.05.2001  10:50:25   þ LBA warning: 1996140
7.05.2001  10:50:27   þ LBA warning: 1996395
7.05.2001  10:50:35   þ LBA Error: 1997180
7.05.2001  10:50:38   þ LBA warning: 2028270
7.05.2001  10:50:38   þ LBA Warning: 2028525
7.05.2001  10:50:38   þ LBA Warning: 2028780
7.05.2001  10:50:39   þ LBA Warning: 2032095
7.05.2001  10:50:41   þ LBA warning: 2036430
7.05.2001  10:50:41   þ LBA Warning: 2039745
7.05.2001  10:50:42   þ LBA warning: 2042295
7.05.2001  10:50:48   þ LBA Error in block: 2044080
7.05.2001  10:50:54   þ LBA Error in block: 2045610
7.05.2001  10:50:55   þ LBA warning: 2051475
7.05.2001  10:51:01   þ LBA Error in block: 2054280
7.05.2001  10:51:07   þ LBA Error in block: 2062440
7.05.2001  10:51:08   þ LBA Warning: 2064225
7.05.2001  10:51:13   þ LBA Error in block: 2065245
7.05.2001  10:51:14   þ LBA Warning: 2067795
7.05.2001  10:51:20   þ LBA Error in block: 2070090
7.05.2001  10:51:21   þ LBA warning: 2071110
7.05.2001  10:51:21   þ LBA Warning: 2071875
7.05.2001  10:51:22   þ LBA warning: 2076210
7.05.2001  10:51:23   þ LBA Warning: 2080545
7.05.2001  10:51:30   þ LBA Error in block: 2082075
7.05.2001  10:51:36   þ LBA Error in block: 2084625
7.05.2001  10:51:37   þ LBA warning: 2086410
7.05.2001  10:51:46   þ LBA Error in block: 2087175
etc.., etc.., etc..
7.05.2001  13:15:13    Blocks > 500ms = 1054
7.05.2001  13:15:13   Errors: 606, Warnings: 1555
7.05.2001  13:15:13   Done
7.05.2001  13:27:24
7.05.2001  13:27:24   MHDD>HELP
7.05.2001  13:27:57
7.05.2001  13:27:57   MHDD>SMART
7.05.2001  13:28:10
7.05.2001  13:28:10   MHDD>SMART ATT
7.05.2001  13:28:10   Getting SMART attributes...
7.05.2001  13:28:10   SMART READ ATTRIBUTES
7.05.2001  13:28:11   HDD: ST9100823A; FW: 8.03; SN: 3LG191VV
7.05.2001  13:28:11   --------------------------------------------------------
7.05.2001  13:28:11   SMART attributes:
7.05.2001  13:28:11               Name                        Val Worst Raw
7.05.2001  13:28:11   Att #   1 : Read error rate           :  66   51  205118579
7.05.2001  13:28:11   Att #   3 : Spin up time              :  96   95  0
7.05.2001  13:28:11   Att #   4 : Number of spin-up times   :  99   99  1894
7.05.2001  13:28:11   Att #   5 : Reallocated sectors count : 100  100  17
7.05.2001  13:28:11   Att #   7 : Seek error rate           :  63   60  86233680
7.05.2001  13:28:11   Att #   9 : Power-on time             :  94   94  5567
7.05.2001  13:28:11   Att #  10 : Spin-up retries           : 100  100  0
7.05.2001  13:28:11   Att #  12 : Start/stop count          :  99   99  1936
7.05.2001  13:28:11   Att # 192 : Power-off retract count   : 100  100  1955
7.05.2001  13:28:11   Att # 193 : Load/unload cycle count   :   5    5  191223
7.05.2001  13:28:11   Att # 194 : HDA Temperature           :  32   72  32
7.05.2001  13:28:11   Att # 195 : Hardware ECC recovered    :  65   51  205118579
7.05.2001  13:28:11   Att # 197 : Current pending sectors   :  88   88  250
7.05.2001  13:28:11   Att # 198 : Offline scan UNC sectors  :  88   88  250
7.05.2001  13:28:11   Att # 199 : Ultra ATA CRC Error Rate  : 200    1  3869
7.05.2001  13:28:11   Att # 200 : Write error rate          : 100  253  0
7.05.2001  13:28:11   Att # 202 : Unknown                   : 100  253  0
Any help is greatly appreciated.
Thank you!
PostPosted: October 29th, 2006, 13:18
I have also tried to do an image by copying the sectors to a new drive.
But without success.I tried it with media tools, but it doesn't get passed CHS 0,0,1 or LBA 0. (it's only the demo version, so I can't set it to ignore bad sectors) I also tried Copyr's HD DUPLICATOR which also hangs on CHS 0,0,1. If I start from CHS 0,0,2 it starts copying sectors but after about 25 sectors complains about not being able to get a signal from the drive anymore. after a few hundred errors it is able to recover about another 20 - 30 sectors and after about 1500 errors and 120 recorded sector just dies. I also tried a few other Duplication programs but the results where similar to the ones described above.
As a side note:
I also had problems with ATA password on this drive.
After spending frustrated time going back and forth I got the Master password. But  when I tried unlocking it with MHDD it would not work.
It was complaining about password being invalid, although I know this is not true. After trying it several times I gave up with the my MHDD unlock atempt(DEll drive). I got the dell xps laptop from which the hard drive originaly was taken and was able to unlock it from the BIOS with the same password. Does DEll do something to 2.5" HD's to prevent the unlocking from tools such as MHDD?
or is it a possible bug in MHDD?
Unfortunaltey I did not test any other tools such as ATAPWD to compare.
If anyone has had similar experience It would be great to share this here.
Thanks again
PostPosted: November 3rd, 2006, 20:15
La, La, la, no one here :shock: :?:
PostPosted: November 9th, 2006, 16:47
BAD sectors is very common in 2.5" Seagate Hard Drives. Do you want to repair the disk or recover the data? If you want to repair the disk I think you would be better replacing it. If you want to recover the data there are many ways to do it. Media Tools should be able to clone this drive, but you will need the registered version as you need to set read retries to 0 (default is 32!). You can also clone the disk in reverse, this way you will likely get all data after first sector and will very likely be able to recover the data. Other option is to add disk to Windows (you can add disk while windows is running and add from Device manager with detect new hardware) and select recovery software with good error control such as R-Studio.
PostPosted: November 9th, 2006, 18:59
Hddguy,
Thanks for the reply!
Yes, I am trying to recover the data. The Device Manager in Windows is crappy. It will make the drive hang. It's because of badly designed interrupts with Plug & Play (I think) :roll: I tried this before! Plus the drive is only intermediately detected in BIOS.
I think PCB is slowly dying as well. But you are right, I will try to set read retries to 0 and if this doesn't work I will try to do a reverse clone. I have thought of this as well but, I only have a demo version of Media Tools which did not give me the opportunity to change these options. I guess I just didn't get around to purchasing full version. But it seams worth it, so I'll go ahead.
Thanks again :D
PostPosted: November 12th, 2006, 3:57
Download Hiren Boot Cd this contains full version of Media Tools .
thanki.tk
PostPosted: November 17th, 2006, 2:25
Have you tried dd_rescue?
PostPosted: November 17th, 2006, 8:23
dd_rescue what is it ?
And what does it do ??
PostPosted: November 17th, 2006, 9:32
... first google hit: http://www.garloff.de/kurt/linux/ddrescue/
It's included on several Linux boot CDs like KNOPPIX and INSERT (UBCD).
PostPosted: November 28th, 2006, 6:31
It seems that prob's not only in bad sector 0, but also in IDE - Cable.
This attribute, unless it has zero raw value, usually means that it's the cable.
Try to change the cable.
Users browsing this forum: No registered users and 179 guests
