 Post subject: My Seagate Barracuda can't fdisk and format
PostPosted: January 13th, 2007, 8:29
Hi, I have a seagate 40GB 7200 rpm. But i can't make any partition (fat32 or with ntfs either) or even format it. I've tried mhdd 'erase' and 'remap' but when they found a bad sector it stoped very long time and never move again. Can any body help ? Thanks a lot.
 Post subject:
PostPosted: January 14th, 2007, 8:54
This drive is very much damaged wouldnt get repaired with any freeware utility i suggest u throw it away and get a new one .
 Post subject:
PostPosted: January 15th, 2007, 3:10
If that so, what do you suggestion to fix it? should i buy PC 3000 PCI the original one or is there any other powerfull software/hardware that not too expensive like PC 3000 for this situation? You right, i don't need to recovered any data from it but i do hava a lot of seagate like that. So, please is there any solution guys? Thanks a lot.
 Post subject:
PostPosted: January 16th, 2007, 3:11
Hi
Should the data not needed, the best thing U can do is to get a new drive not spending too much time on the bad one.
 Post subject:
PostPosted: January 18th, 2007, 13:23
Salvation data for seagate is good for this drive but it is about 450$ if u can afford it then buy .
 Post subject:
PostPosted: January 18th, 2007, 18:13
H e w r o t e h e d o e s n ' t n e e d t h e d a t a :)
 Post subject: ~
PostPosted: January 19th, 2007, 14:54
I agree the PCI PC3000 can help you :P
 Post subject:
PostPosted: January 20th, 2007, 0:08
the case is same with me, after i flash my hdd it cann't fdisk & format
 Post subject: really....
PostPosted: January 22nd, 2007, 6:07
So rameez is that true Salvation Data can fix my problem ? I don't have to retrieved my data from it. I have a lot of HDD at my store that has this kind of problem. If it's true, $450 it doesn't matter with me. Have ever tried Salvation Data before?
Thanks rameez...
 Post subject:
PostPosted: January 22nd, 2007, 15:26
Run a full erase with Seagate utility (DiscWizard) and see if that helps.
 Post subject:
PostPosted: January 23rd, 2007, 3:35
Thanks weaker, nope it's not possible i allready tried. But thanks a lot for joining.
 Post subject:
PostPosted: January 23rd, 2007, 15:00
yes it would help has worked for me .
 Post subject:
PostPosted: January 24th, 2007, 1:58
thanks rameez .... :D
Users browsing this forum: Pi0tR and 92 guests
