 Post subject: slow spins
PostPosted: March 26th, 2007, 16:05
Hi to all!!
hdd toshiba MK6021GAS
THE MOTOR SPINS VERY SLOWLY (30 RPM) AS I DO IN ORDER THAT IT WORKS TO (REVOLVE)
Нет ничего невозможного
 Post subject:
PostPosted: March 27th, 2007, 3:31
Suggestions:
1. Apply hot air to underneath of spindle.
2. Loosen silver disk underneath and re-apply lubricant to spindle
3. Swap platter to good shell.
 Post subject: THANKS FOR HELP PCIMAGE!! CHECK PM..
PostPosted: March 27th, 2007, 8:00
pcimage wrote:
Suggestions:
:idea: :idea:
 Post subject:
PostPosted: March 29th, 2007, 17:05
What is a technique to remove that spindle bearing cap on the bottom of drives anyways? Do they usually spin out? I've seen people cut a groove into the cap with a dremel which I assume is to use a screwdriver to spin the cap out.
Users browsing this forum: Bing [Bot], Google [Bot] and 346 guests
