 Post subject: Seagate St380011A problem
PostPosted: May 17th, 2007, 4:43
I have a seagate ST380011A 80 GB 8.01 Hard disk It gives error .
HEAD MASK FFFF. HEAD MASK FFFF. HEAD MASK FFFF.
What could be done to recover data. Please advice
DF
PostPosted: May 17th, 2007, 5:52
1st: replace PCB to make sure it's OK
 Post subject: yeah
PostPosted: May 17th, 2007, 8:45
head damaged !!!!
 Post subject: Re: Seagate St380011A problem
PostPosted: May 17th, 2007, 11:35
darkfroce1 Check the -5V for the preamp and spindle IC (Smooth/SHxxxx) or could try known good suitable PCB.
If problem persis most common you will need head exchage.
DataRecovery.bg
PostPosted: May 17th, 2007, 12:56
darkfroce1 show full log of the terminal when enabling the voltage,
HEAD MASK FFFF - Many reason Can be caused from loss of information in flash (start from masks like M-11), before faulty heads\preamp (absence of his power).
2 Samo Sometimes resistor is torn off on lines +5v (Preamp power).
PostPosted: May 17th, 2007, 15:01
Thanks for the reply. I have changed the PCB and also tried hot swap. I thinnk its Head problem. Will post log tomorrow.
DF
PostPosted: May 19th, 2007, 14:24
Yes thats true.
DataRecovery.bg
PostPosted: May 19th, 2007, 16:54
Thanks and Regards to Everyone.
DF :)
Users browsing this forum: ccc and 91 guests
