 Post subject: REVERSED POLARITY!-WESTERN DIGITAL WD2000JB - 00GVC00 HELP!
PostPosted: May 17th, 2007, 9:15
Hi there
i have a WD2000JB - 00GVC00
25 sept 2005
I have reversed the polarity on it (pretty damn sure) by plugging in the wrong DC adapter.
Now the light just flashes and no spin no noise.
Is it totally screwed? Will a logic board swap help here?
Image thanks
Harky
PostPosted: May 17th, 2007, 10:54
Yes, you can try PCB swap from the same drive.
PostPosted: May 17th, 2007, 13:23
If has occurred change polarity on by plugging - 99% preamp has died :( , if he in short circuits possible to kill alive pcb :!:
harky If you need information from this hdd then address to specialist in the field of data recovery.
 Post subject: PREAMP>!?
PostPosted: May 17th, 2007, 18:30
which bit is the preamp?
is it on the logic board??
will replacing the logic board fix it?
PostPosted: May 17th, 2007, 19:19
Preamp is inside the HDA, mounted on the Head Assembly.
Since it is inside the clean area, it is not really easy to replace it.
regards,
 Post subject: pre amp
PostPosted: May 18th, 2007, 6:51
really?
thats shit.
does that mean i have to send it in?
logic replace wont help?
how sure are you?
PostPosted: May 18th, 2007, 23:24
Shortscurcuits :D :D
Seriously what Pepe was saying is that there is a good chance you damaged the pre-amp also. Try to find the same model drive for a donor, if the DCM code is different on the new PCB you will need to change the rom chip also. Just be prepared to sacrifice the cost of a donor HDD to test if the pre-amp is OK or not. If it died when you shorted the drive,and that is often the case, it will usually kill your new PCB. If you really need the data you will have to use a data recovery center or be prepared to take a chance on opening the drive to do a head swap or a pre-amp chip soldering job, neither of which is an easy job. You would want to practice on some donor drives and head swaps on WD are difficult to re-align new heads so the drive can read anything once changed. Also if you aren't successful doing the head change it would make recovery very difficult for a DR company. The upper screw in the lid helps to position the heads on these drives and once loosened they are hard to align again.
I think ST is a sub company of Lucas
Users browsing this forum: ccc and 94 guests
