 Post subject: Seagate ST3200822A Problem
PostPosted: June 10th, 2007, 5:02
To all respected Guru's
I have received 200 GB Seagate hard disk. Which was having motor jam problem with head stucked on media
Seagate ST3200822A 3.01 IDE
Although I have replace the media to another doner successfully 2 data Plates without misalignment them.
And replaced the head (original as doner is not available) now the disk spins ok but it remains BSY and DSC signal after 15-20 sec it gives error
Here is the terminal Log when power up
Interface task reset
4096k x 16 buffer detected
APLUS - 1_Disk S.07 02-09-04 16:00
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
3.01 02-09-04 16:01
(P)PATA Reset
---------------- This one after 10 to 15 sec------------------
CE Log EC=0 Rtype=36 OV=0 STStatus0
$Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF -
Need data please guide
With Regards
DF
 Post subject:
PostPosted: June 10th, 2007, 6:18
Sounds like either the heads are duff, or the platter swap didn't quite go to plan.
Anyway, how do you know you've successfully transplanted the platters without misaligning them? The drive still doesn't work!
 Post subject:
PostPosted: June 10th, 2007, 6:54
thanks Sean
there is no chance of media misalignment. Its a 100% sure and success technique which i have made.
It could be head. Because when I opened the Disk when it came. head was stuck and client told me that drive felled when he was transferring data. This made bearing Jam. And can see a very tiny small dot marking on the top media head3. But lowest media is fine.
Secondly when i power up the disk i can see head comes till center only instead of going till the outer of media.
Any suggestion regarding the terminal report
DF
 Post subject:
PostPosted: June 10th, 2007, 14:42
Please advice
thanks
DF
Users browsing this forum: arvika and 62 guests
