 Post subject: Need help for Seagate ST3200822AS
PostPosted: June 21st, 2007, 17:17
Dear Forum,
my seagate barracuda ST3200822AS died without any warning. It is recognized in BIOS but can't boot WindowsXP nor access any data.
Because i wanna try to save some photos i need your help.
If i scan the disk with HDDScan i get a lot of bad blocks with spaces of good blocks between.
Today i connected COM Port to my HDD to get some more info:
Interface task reset
4096k x 16 buffer detected
APLUS - 1_Disk S.07 03-31-04 15:51
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
3.01 04-07-04 16:59
(P)SATA Reset
CE Log EC=0 Rtype=36 OV=0 STStatus0
Mesa C3 Grand C Stuff Mesa 0A/95C7/954F Native mode
RD:0200:10
WR:0210:10
AC:022B:01FF
AS:042A:007F
SC:04A9:0201
DP:022B:01FF
BA:0227:03
ST:022A:01
logbps:0200
codebps:0200
uP:3FE2:1E
FM:0220:07
AD:0220:0B
RL:3FDD
SL:3F1A
AL:3F03
MZ:3FF6
Age Typ Hds Lent Loopcnt TrkGn Thld Grey Intg TrkOfst SpnIntg
50 E3 3 0000 0000000 0023 01081B 0092 0000 09B5
.Pgm=00 Trk=0FA9D(0FA9D[1081B]).0(0).007(006) Zn=0 Err=00 ErCt=0000 Hlth=0018 CHlth=0000 Ready LBA=00000000
;Age=50 Type=E3 MxCyl=17C5C MxHd=3 MxSct=4D0 BSz=2000 TCode=0000
:50000018E3000003 AX`5LJ06GQ2' "000000000000"0FA52-0FAD1
SRAM Ovly = AT
AT Er 00 Nwt Er 43 RdWr 0974b.02.00e2
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 4074346b ff 4074346b.0.000 000f 0001 0001 0000
AutoRd Err 47 at 00974b.02.00e2
CE Log EC=43 Rtype=25 OV=0 STStatus79
SCAN Error
AT Er 00 Nwt Er 43 RdWr 0974b.02.00e3
AutoRd Err 47 at 00974b.02.00e3
SCAN Error
APLUS - 2_Disk 3.01 04-07-04 16:59
Built for APLUS,GRAND2,Diamondback,TI1761 PreAmp,STL6 Andante PreAmp,InternalSpin,GC110,SVC127,OneToOne,2Disk,LowDelta,220 Servos,7200RPM,8Pole,NonModGray,100MHz,Code DRAM,Early Exit,Stall Converter,RwFeat=0600,SeaDex,MDW
SCAN Error
AT Er 00 Nwt Er 43 RdWr 0974b.02.00e4
AutoRd Err 47 at 00974b.02.00e4
SCAN Error
I bought a second HDD with nearly same parameters except config and site code to change PCB, but it didn't work at all.
I tried making a image/ clone to the second HDD but due to bad blocks it would take thousands of hours.
What else can i do to recover some data?
Thanks a lot in advance!
Leo
 Post subject:
PostPosted: June 22nd, 2007, 0:13
If MHDD or another soft show XXXXXXXXXXXXXX then good block another XXXXXXXXXXXX and so so, maybe u have a Bad or weak Head.
Users browsing this forum: arvika and 56 guests
