 Post subject: Seagate 7200.7 report
PostPosted: July 17th, 2007, 7:38
Hi I get following terminal report for seagate 160 GB 7200.7 Pata hard disk model ST3160023A F/w 3.06
Kindly let me know what these messages means and how i should go ahead with data recovery? Are heads of this hdd are damaged?
Thank you
Kiran
Interface task reset
4096k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Buzz - Head Mask 000F - Switch to full int.
Spin Ready
3.06 01-29-04 11:20
(P)PATA Reset
F>
F>
Switching HDD power supply OFF
Selected family......................... : Barracuda 7200.7
Selected model.......................... : ST3160023A
Model by ID............................. : <HDD ID NOT READ>
Detection of HDD COM port baud rate..... : Error
Terminal : reply timeout error
Error switching COM port baud rate
Initializing Safe Mode...
Switching HDD power supply ON
COM transfer baud rate set to 19200
Terminal : detecting SA bounds...
Detection of SA bounds by MUX
SA bounds identified
Test : Reading SA surface by PCHS (terminal)
Location (PCHS).......... : 0xE31B : 0x0 : 0x0
Number................... : 0x180
HDD profile file......... : D:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.7\new shi\Data\PCHS 0x00E31B_0x00_0x0000(0x0180).chs
Result.................................. : Error
Test : Saving LDR from HDD
HDD profile file......... : D:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.7\new shi\Data\LDR\SgLDR.ldr
Will be stored........... : ROM, App, CERT code, CERT tables, Ovl 0, Stuff, DRV cfg
DRV cfg reading...
DRV cfg reading......................... : This action is impossible in Safe mode!
Executing user command.................. : Show ROM information
Executing user command.................. : Show PCB information
Executing user command.................. : Show User track slip list (P-List)
Test : ROM reading (terminal)
ROM file type............ : Programmer image
HDD profile file......... : D:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.7\new shi\Data\ROM\ROM.bin
Error connecting to Serial Flash!
Error : Terminal : reply timeout error
HDD reply :
Location (PCHS).......... : 0x0 : 0x0 : 0x0
Number................... : 0x0
Result.................................. : Ok
 Post subject: Re: Seagate 7200.7 report
PostPosted: July 17th, 2007, 10:32
you hard disk its knocking? its showing BSY , or get DRDY DSC?
PostPosted: July 18th, 2007, 1:52
Hi thanks BETO No its not knocking and neither showing busy or any other status.
Users browsing this forum: No registered users and 72 guests
