 Post subject: Need Help for WD400BB (no data access)
PostPosted: June 28th, 2007, 10:33
Hello to all Gurus
I have a WD400BB hard disk. Detects Ok but when i try to access the data it gives ABR and ERR signal and when I do Module check it gives error on Module 32 (Translator).
Do i have to regenerate translator. Please guide.
DF
 Post subject:
PostPosted: June 28th, 2007, 10:55
-Backup SA
-Clear G-List
-Regenerate Translator
*Header on Module 32 must be OK...
Mikippp
 Post subject:
PostPosted: June 28th, 2007, 10:56
Thanks you MikiPPP sir
DF :)
 Post subject:
PostPosted: June 28th, 2007, 11:04
Before doing what U said when i try to read module 32 it goes till 75% and then gives " Module read error physical read error C/H/S -2/0-508 Techno CMD sending Device Error Detected 51/04 ABR read error " so it it a header problem or there is Bad Sector in SA.
and will your (Mikippp) meathord work.
DF
 Post subject:
Please read -2/0-508 Techno as -2/0/508
 Post subject:
PostPosted: June 28th, 2007, 12:08
Guys ,
You Know Whats The Greatest Thing .When You Regenerate The Translator ,The Data Is Visible ,Why ?
1 :How Does The Regeneration of Translator Make Sure You Can Access The Same Sectors Which Have The Data .Even 1 Sector Misplacement Will Make Data Useless .This is a Beautiful Algorithm .Really Beautiful
 Post subject: Re: Need Help for WD400BB (no data access)
PostPosted: September 20th, 2007, 5:26
Darkforce did you mange to get drive to work? i have same problem Module read error physical read error C/H/S?
Users browsing this forum: Google [Bot] and 81 guests
