 Post subject: Firmware Need For WD400BD-75LRA0
PostPosted: October 24th, 2007, 17:33
I have a Western Digital Drive
WD400BD-75LRA0
DCM= HSBHYTJCH
SN= WMAMC5060128
Drive is detecting as a WDC ROM MODEL UNICORN does anyone have the firmware or have worked on this drive before?
Thank you.
 Post subject: Re: Firmware Need For WD400BD-75LRA0
PostPosted: October 25th, 2007, 13:23
Does it click?
Does it spin up?
Did you change PCB on it?
PostPosted: October 26th, 2007, 0:07
It Spins no clickiing havnt found a matching PCB but after seeing the way the drive detected as a WDC ROM Unicorn it seemed like firmware.
PostPosted: October 26th, 2007, 2:32
It is nacessary to resolder native ROM !!!
Mikippp
PostPosted: October 27th, 2007, 4:39
ROM - U12 (25P10, AT25F1024, SST25VF010)
Mikippp
PostPosted: October 28th, 2007, 13:46
Thank you for your comments.
PostPosted: November 16th, 2007, 16:26
Is this the only way to resolder this chip or is there any firmware for this drive?
PostPosted: November 16th, 2007, 19:32
The PCB is burnt? The Drive is just detecting as a unicorn.
PostPosted: November 16th, 2007, 23:36
Yes that is what I mean seems like bad firmware & I do Have PC3K PCI anyone have the firmware?
PostPosted: November 19th, 2007, 2:00
Do you know the F/W version and Link version you need?
PostPosted: November 19th, 2007, 10:25
Firmware REV A00 For PC-3000PCI
PostPosted: November 20th, 2007, 22:45
Looks like the translator module is corrupt. Module 31 and 32.
PostPosted: November 21st, 2007, 9:08
This was the generated Report
Id:Copy: Importance:Cyl :Head:Sector:Size:Read : Hdr : CS : CS Value: Date : Vers.: Desription
01: 0 : As : -1: 0: 0: 2:Yes : Ok : Ok : 6D :29-06-05:06BB? :Modules directory
01: 1 : As : -33: 0: 0: 2:Yes : Ok : Ok : 6D :29-06-05:06BB? :Modules directory
31: 0 : Ad : -1: 0: 6: 176:Yes : Ok : Ok : 36 :20-08-49:1500? :Translator
31: 1 : Ad : -33: 0: 6: 176:Yes : Ok : Ok : 36 :20-08-49:1500? :Translator
17: 0 : B : -1: 0: 192: 30:Yes : Ok : Ok : 62 :26-05-05:06BBD :Loaded part of microprogram code
17: 1 : B : -33: 0: 192: 30:Yes : Ok : Ok : 62 :26-05-05:06BBD :Loaded part of microprogram code
15: 0 : B : -1: 0: 232: 13:Yes : Ok : Ok : A5 :26-05-05:06BBD :Loaded part of microprogram code
15: 1 : B : -33: 0: 232: 13:Yes : Ok : Ok : A5 :26-05-05:06BBD :Loaded part of microprogram code
04: 0 : B : -1: 0: 255: 9:Yes : Ok : Ok : 0D :26-05-05:0200? :Family models configuration (Main)
04: 1 : B : -33: 0: 255: 9:Yes : Ok : Ok : 0D :26-05-05:0200? :Family models configuration (Main)
4A: 0 : As : -1: 0: 268: 4:Yes : Ok : Ok : 08 :26-05-05:06BB? :Adaptive data
4A: 1 : As : -33: 0: 268: 4:Yes : Ok : Ok : 08 :26-05-05:06BB? :Adaptive data
52: 0 : As : -1: 0: 276: 2:Yes : Ok : Ok : 5D :26-05-05:06BB? :Parameters table 3
52: 1 : As : -33: 0: 276: 2:Yes : Ok : Ok : 5D :26-05-05:06BB? :Parameters table 3
35: 0 : : -2: 0: 0: 1:Yes : Ok : Ok : AC :13-10-02:6000? :
35: 1 : : -34: 0: 0: 1:Yes : Ok : Ok : AC :13-10-02:6000? :
02: 0 : B : -2: 0: 5: 2:Yes : Ok : Ok : 88 :26-05-05:0800? :Configuration (HDD ID)
02: 1 : B : -34: 0: 5: 2:Yes : Ok : Ok : 88 :26-05-05:0800? :Configuration (HDD ID)
33: 0 : Dd : -2: 0: 11: 290:Yes : Ok : Ok : 5A :26-05-05:1500? :P-List (Primary defect list)
33: 1 : Dd : -34: 0: 11: 290:Yes : Ok : Ok : 5A :26-05-05:1500? :P-List (Primary defect list)
26: 0 : : -2: 0: 305: 129:Yes : Ok : Ok : 0C :26-05-05:06BB? :
26: 1 : : -34: 0: 305: 129:Yes : Ok : Ok : 0C :26-05-05:06BB? :
1C: 0 : B : -2: 0: 438: 27:Yes : Ok : Ok : D6 :26-05-05:06BBD :Loaded part of microprogram code
1C: 1 : B : -34: 0: 438: 27:Yes : Ok : Ok : D6 :26-05-05:06BBD :Loaded part of microprogram code
4C: 0 : B : -2: 0: 475: 13:Yes : Ok : Ok : 8A :26-05-05:06BBD :Loaded part of microprogram code
4C: 1 : B : -34: 0: 475: 13:Yes : Ok : Ok : 8A :26-05-05:06BBD :Loaded part of microprogram code
07: 0 : B : -2: 0: 498: 9:Yes : Ok : Ok : CE :26-05-05:0200? :Family models configuration (Alt3)
07: 1 : B : -34: 0: 498: 9:Yes : Ok : Ok : CE :26-05-05:0200? :Family models configuration (Alt3)
53: 0 : As : -2: 0: 511: 2:Yes : Ok : Ok : BE :26-05-05:06BB? :Parameters table 4
53: 1 : As : -34: 0: 511: 2:Yes : Ok : Ok : BE :26-05-05:06BB? :Parameters table 4
2E: 0 : : -3: 0: 0: 284:Yes : Ok : Ok : 68 :26-05-05:06BB? :
2E: 1 : : -35: 0: 0: 284:Yes : Ok : Ok : 68 :26-05-05:06BB? :
1B: 0 : B : -3: 0: 294: 93:Yes : Ok : Ok : A4 :26-05-05:06BBD :Loaded part of microprogram code
1B: 1 : B : -35: 0: 294: 93:Yes : Ok : Ok : A4 :26-05-05:06BBD :Loaded part of microprogram code
19: 0 : B : -3: 0: 397: 25:Yes : Ok : Ok : BF :26-05-05:06BBD :Loaded part of microprogram code
19: 1 : B : -35: 0: 397: 25:Yes : Ok : Ok : BF :26-05-05:06BBD :Loaded part of microprogram code
41: 0 : As : -3: 0: 432: 19:Yes : Ok : Ok : 04 :26-05-05:06BB? :Adaptive data
41: 1 : As : -35: 0: 432: 19:Yes : Ok : Ok : 04 :26-05-05:06BB? :Adaptive data
05: 0 : B : -3: 0: 455: 9:Yes : Ok : Ok : AB :26-05-05:0200? :Family models configuration (Alt1)
05: 1 : B : -35: 0: 455: 9:Yes : Ok : Ok : AB :26-05-05:0200? :Family models configuration (Alt1)
0C: 0 : B : -3: 0: 468: 3:Yes : Ok : Ok : 26 :26-05-05:0100? :Models table
0C: 1 : B : -35: 0: 468: 3:Yes : Ok : Ok : 26 :26-05-05:0100? :Models table
37: 0 : : -3: 0: 475: 1:Yes : Ok : Ok : E4 :26-05-05:0100? :
37: 1 : : -35: 0: 475: 1:Yes : Ok : Ok : E4 :26-05-05:0100? :
2D: 0 : : -8: 0: 0: 284:Yes : Ok : Ok : 69 :26-05-05:06BB? :
2D: 1 : : -40: 0: 0: 284:Yes : Ok : Ok : 69 :26-05-05:06BB? :
21: 0 : B : -8: 0: 294: 62:Yes : Ok : Ok : 8D :26-05-05:2106? :S.M.A.R.T.
21: 1 : B : -40: 0: 294: 62:Yes : Ok : Ok : 8D :26-05-05:2106? :S.M.A.R.T.
1E: 0 : B : -8: 0: 360: 23:Yes : Ok : Ok : F9 :26-05-05:06BBD :Loaded part of microprogram code
1E: 1 : B : -40: 0: 360: 23:Yes : Ok : Ok : F9 :26-05-05:06BBD :Loaded part of microprogram code
40: 0 : As : -8: 0: 393: 19:Yes : Ok : Ok : E7 :26-05-05:06BB? :Adaptive data
40: 1 : As : -40: 0: 393: 19:Yes : Ok : Ok : E7 :26-05-05:06BB? :Adaptive data
32: 0 : Ad : -8: 0: 416: 8:No : : : : : :Translator
32: 1 : Ad : -40: 0: 416: 8:No : : : : : :Translator
36: 0 : : -8: 0: 428: 2:Yes : Ok : Ok : 6F :26-05-05:06BB? :
36: 1 : : -40: 0: 428: 2:Yes : Ok : Ok : 6F :26-05-05:06BB? :
11: 0 : B : -9: 0: 0: 252:Yes : Ok : Ok : F3 :26-05-05:06BBD :Loaded part of microprogram code
11: 1 : B : -41: 0: 0: 252:Yes : Ok : Ok : F3 :26-05-05:06BBD :Loaded part of microprogram code
23: 0 : B : -9: 0: 262: 62:Yes : Ok : Ok : 01 :26-05-05:2106? :S.M.A.R.T. Log (reserved)
23: 1 : B : -41: 0: 262: 62:Yes : Ok : Ok : 01 :26-05-05:2106? :S.M.A.R.T. Log (reserved)
43: 0 : As : -9: 0: 328: 19:Yes : Ok : Ok : 16 :26-05-05:06BB? :Adaptive data
43: 1 : As : -41: 0: 328: 19:Yes : Ok : Ok : 16 :26-05-05:06BB? :Adaptive data
39: 0 : : -9: 0: 351: 17:Yes : Ok : Ok : 69 :26-05-05:06BB? :
39: 1 : : -41: 0: 351: 17:Yes : Ok : Ok : 69 :26-05-05:06BB? :
2F: 0 : B : -9: 0: 372: 5:Yes : Ok : Ok : 61 :26-05-05:06BBD :Loaded part of microprogram code
2F: 1 : B : -41: 0: 372: 5:Yes : Ok : Ok : 61 :26-05-05:06BBD :Loaded part of microprogram code
49: 0 : As : -9: 0: 381: 2:Yes : Ok : Ok : 9D :26-05-05:06BB? :Adaptive data
49: 1 : As : -41: 0: 381: 2:Yes : Ok : Ok : 9D :26-05-05:06BB? :Adaptive data
38: 0 : : -10: 0: 0: 257:Yes : Ok : Ok : D2 :26-05-05:06BB? :
38: 1 : : -42: 0: 0: 257:Yes : Ok : Ok : D2 :26-05-05:06BB? :
22: 0 : B : -10: 0: 261: 62:Yes : Ok : Ok : 8B :26-05-05:2106? :S.M.A.R.T.
22: 1 : B : -42: 0: 261: 62:Yes : Ok : Ok : 8B :26-05-05:2106? :S.M.A.R.T.
28: 0 : : -10: 0: 327: 19:Yes : Ok : Ok : 4F :28-06-05:0300? :
28: 1 : : -42: 0: 327: 19:Yes : Ok : Ok : 4F :28-06-05:0300? :
34: 0 : C : -10: 0: 350: 12:Yes : Ok : Ok : 97 :26-05-05:1500? :G-List (Grown defect list)
34: 1 : C : -42: 0: 350: 12:Yes : Ok : Ok : 97 :26-05-05:1500? :G-List (Grown defect list)
29: 0 : : -10: 0: 366: 5:Yes : Ok : Ok : 26 :26-05-05:06BB? :
29: 1 : : -42: 0: 366: 5:Yes : Ok : Ok : 26 :26-05-05:06BB? :
50: 0 : As : -10: 0: 375: 2:Yes : Ok : Ok : F0 :26-05-05:06BB? :Parameters table 1
50: 1 : As : -42: 0: 375: 2:Yes : Ok : Ok : F0 :26-05-05:06BB? :Parameters table 1
25: 0 : : -11: 0: 0: 257:Yes : Ok : Ok : 8C :26-05-05:06BB? :
25: 1 : : -43: 0: 0: 257:Yes : Ok : Ok : 8C :26-05-05:06BB? :
24: 0 : B : -11: 0: 261: 62:Yes : Ok : Ok : 31 :26-05-05:2106? :S.M.A.R.T. Log (reserved)
24: 1 : B : -43: 0: 261: 62:Yes : Ok : Ok : 31 :26-05-05:2106? :S.M.A.R.T. Log (reserved)
42: 0 : As : -11: 0: 327: 19:Yes : Ok : Ok : 3F :26-05-05:06BB? :Adaptive data
42: 1 : As : -43: 0: 327: 19:Yes : Ok : Ok : 3F :26-05-05:06BB? :Adaptive data
06: 0 : B : -11: 0: 350: 10:Yes : Ok : Ok : ED :26-05-05:0200? :Family models configuration (Alt2)
06: 1 : B : -43: 0: 350: 10:Yes : Ok : Ok : ED :26-05-05:0200? :Family models configuration (Alt2)
2A: 0 : : -11: 0: 364: 5:Yes : Ok : Ok : EF :26-05-05:06BB? :
2A: 1 : : -43: 0: 364: 5:Yes : Ok : Ok : EF :26-05-05:06BB? :
51: 0 : As : -11: 0: 373: 2:Yes : Ok : Ok : B5 :26-05-05:06BB? :Parameters table 2
51: 1 : As : -43: 0: 373: 2:Yes : Ok : Ok : B5 :26-05-05:06BB? :Parameters table 2
C4: 0 : Dr : -9: 0: 387: 103:Yes : Ok : Ok : 2D :26-05-05:R.9C? :Calibrations module
C4: 1 : Dr : -41: 0: 387: 103:Yes : Ok : Ok : 2D :26-05-05:R.9C? :Calibrations module
C5: 0 : Dr : -3: 0: 480: 3:Yes : Ok : Ok : 07 :26-05-05:R.01? :Calibration script (DCM)
C5: 1 : Dr : -35: 0: 480: 3:Yes : Ok : Ok : 07 :26-05-05:R.01? :Calibration script (DCM)
CC: 0 : Dr : -3: 0: 483: 6:Yes : Ok : Ok : B1 :26-05-05:R.9C? :Calibrations module
CC: 1 : Dr : -35: 0: 483: 6:Yes : Ok : Ok : B1 :26-05-05:R.9C? :Calibrations module
CA: 0 : Dr : -3: 0: 489: 6:Yes : Ok : Ok : 9D :26-05-05:R.9C? :Calibrations module
CA: 1 : Dr : -35: 0: 489: 6:Yes : Ok : Ok : 9D :26-05-05:R.9C? :Calibrations module
CB: 0 : Dr : -3: 0: 495: 6:Yes : Ok : Ok : 41 :26-05-05:R.9C? :Calibrations module
CB: 1 : Dr : -35: 0: 495: 6:Yes : Ok : Ok : 41 :26-05-05:R.9C? :Calibrations module
CD: 0 : Dr : -3: 0: 501: 6:Yes : Ok : Ok : 61 :26-05-05:R.9C? :Calibrations module
CD: 1 : Dr : -35: 0: 501: 6:Yes : Ok : Ok : 61 :26-05-05:R.9C? :Calibrations module
CF: 0 : Dr : -3: 0: 507: 6:Yes : Ok : Ok : CC :26-05-05:R.9C? :Calibrations module
CF: 1 : Dr : -35: 0: 507: 6:Yes : Ok : Ok : CC :26-05-05:R.9C? :Calibrations module
CE: 0 : Dr : -8: 0: 434: 6:Yes : Ok : Ok : C4 :26-05-05:R.9C? :Calibrations module
CE: 1 : Dr : -40: 0: 434: 6:Yes : Ok : Ok : C4 :26-05-05:R.9C? :Calibrations module
91: 0 : Dr : -3: 0: 513: 1:Yes : Ok : Ok : 0F :26-05-05:R.9C? :Calibrations module
91: 1 : Dr : -35: 0: 513: 1:Yes : Ok : Ok : 0F :26-05-05:R.9C? :Calibrations module
92: 0 : Dr : -3: 0: 514: 1:Yes : Ok : Ok : 0E :26-05-05:R.9C? :Calibrations module
92: 1 : Dr : -35: 0: 514: 1:Yes : Ok : Ok : 0E :26-05-05:R.9C? :Calibrations module
93: 0 : Dr : -8: 0: 440: 6:Yes : Ok : Ok : 08 :26-05-05:R.9C? :Calibrations module
93: 1 : Dr : -40: 0: 440: 6:Yes : Ok : Ok : 08 :26-05-05:R.9C? :Calibrations module
C1: 0 : Dr : -3: 0: 515: 1:Yes : Ok : Ok : AF :26-05-05:R.9C? :Calibrations module
C1: 1 : Dr : -35: 0: 515: 1:Yes : Ok : Ok : AF :26-05-05:R.9C? :Calibrations module
C2: 0 : Dr : -8: 0: 446: 2:Yes : Ok : Ok : DE :26-05-05:R.9C? :Calibrations module
C2: 1 : Dr : -40: 0: 446: 2:Yes : Ok : Ok : DE :26-05-05:R.9C? :Calibrations module
C7: 0 : Dr : -3: 0: 516: 1:Yes : Ok : Ok : D9 :26-05-05:R.9C? :Calibrations module
C7: 1 : Dr : -35: 0: 516: 1:Yes : Ok : Ok : D9 :26-05-05:R.9C? :Calibrations module
9E: 0 : Dr : -8: 0: 448: 3:Yes : Ok : Ok : 00 :26-05-05:R.9C? :Calibrations module
9E: 1 : Dr : -40: 0: 448: 3:Yes : Ok : Ok : 00 :26-05-05:R.9C? :Calibrations module
B1: 0 : : -8: 0: 451: 5:Yes : Ok : Ok : 36 :26-05-05:0112? :
B1: 1 : : -40: 0: 451: 5:Yes : Ok : Ok : 36 :26-05-05:0112? :
E0: 0 : Dr : -6: 0: 0: 510:Yes : Ok : Ok : 76 :26-05-05:620C? :Selfscan module
E0: 1 : Dr : -38: 0: 0: 510:Yes : Ok : Ok : 76 :26-05-05:620C? :Selfscan module
E8: 0 : Dr : -7: 0: 0: 429:Yes : Ok : Ok : 6D :26-05-05:620C? :Selfscan module
E8: 1 : Dr : -39: 0: 0: 429:Yes : Ok : Ok : 6D :26-05-05:620C? :Selfscan module
FE: 0 : Dr : -10: 0: 381: 128:Yes : Ok : Ok : 43 :26-05-05:620C? :Selfscan module
FE: 1 : Dr : -42: 0: 381: 128:Yes : Ok : Ok : 43 :26-05-05:620C? :Selfscan module
D5: 0 : Dr : -11: 0: 379: 110:Yes : Ok : Ok : E7 :26-05-05:620C? :Selfscan module
D5: 1 : Dr : -43: 0: 379: 110:Yes : Ok : Ok : E7 :26-05-05:620C? :Selfscan module
DA: 0 : Dr : -12: 0: 0: 99:Yes : Ok : Ok : 15 :26-05-05:620C? :Selfscan module
DA: 1 : Dr : -44: 0: 0: 99:Yes : Ok : Ok : 15 :26-05-05:620C? :Selfscan module
DB: 0 : Dr : -12: 0: 99: 96:Yes : Ok : Ok : 13 :26-05-05:620C? :Selfscan module
DB: 1 : Dr : -44: 0: 99: 96:Yes : Ok : Ok : 13 :26-05-05:620C? :Selfscan module
DF: 0 : Dr : -12: 0: 195: 110:Yes : Ok : Ok : 35 :26-05-05:620C? :Selfscan module
DF: 1 : Dr : -44: 0: 195: 110:Yes : Ok : Ok : 35 :26-05-05:620C? :Selfscan module
DD: 0 : Dr : -12: 0: 305: 89:Yes : Ok : Ok : 9D :26-05-05:620C? :Selfscan module
DD: 1 : Dr : -44: 0: 305: 89:Yes : Ok : Ok : 9D :26-05-05:620C? :Selfscan module
D6: 0 : Dr : -12: 0: 394: 93:Yes : Ok : Ok : 8A :26-05-05:620C? :Selfscan module
D6: 1 : Dr : -44: 0: 394: 93:Yes : Ok : Ok : 8A :26-05-05:620C? :Selfscan module
D7: 0 : Dr : -13: 0: 0: 91:Yes : Ok : Ok : 3C :26-05-05:620C? :Selfscan module
D7: 1 : Dr : -45: 0: 0: 91:Yes : Ok : Ok : 3C :26-05-05:620C? :Selfscan module
D2: 0 : Dr : -13: 0: 91: 86:Yes : Ok : Ok : 44 :26-05-05:620C? :Selfscan module
D2: 1 : Dr : -45: 0: 91: 86:Yes : Ok : Ok : 44 :26-05-05:620C? :Selfscan module
BB: 0 : Dr : -7: 0: 429: 76:Yes : Ok : Ok : 5B :26-05-05:620C? :Selfscan module
BB: 1 : Dr : -39: 0: 429: 76:Yes : Ok : Ok : 5B :26-05-05:620C? :Selfscan module
D9: 0 : Dr : -13: 0: 177: 77:Yes : Ok : Ok : 1F :26-05-05:620C? :Selfscan module
D9: 1 : Dr : -45: 0: 177: 77:Yes : Ok : Ok : 1F :26-05-05:620C? :Selfscan module
D4: 0 : Dr : -13: 0: 254: 72:Yes : Ok : Ok : 47 :26-05-05:620C? :Selfscan module
D4: 1 : Dr : -45: 0: 254: 72:Yes : Ok : Ok : 47 :26-05-05:620C? :Selfscan module
DC: 0 : Dr : -13: 0: 326: 72:Yes : Ok : Ok : 86 :26-05-05:620C? :Selfscan module
DC: 1 : Dr : -45: 0: 326: 72:Yes : Ok : Ok : 86 :26-05-05:620C? :Selfscan module
D0: 0 : Dr : -13: 0: 398: 71:Yes : Ok : Ok : 19 :26-05-05:620C? :Selfscan module
D0: 1 : Dr : -45: 0: 398: 71:Yes : Ok : Ok : 19 :26-05-05:620C? :Selfscan module
D3: 0 : Dr : -14: 0: 0: 71:Yes : Ok : Ok : 3D :26-05-05:620C? :Selfscan module
D3: 1 : Dr : -46: 0: 0: 71:Yes : Ok : Ok : 3D :26-05-05:620C? :Selfscan module
BA: 0 : Dr : -14: 0: 71: 82:Yes : Ok : Ok : 93 :26-05-05:620C? :Selfscan module
BA: 1 : Dr : -46: 0: 71: 82:Yes : Ok : Ok : 93 :26-05-05:620C? :Selfscan module
B9: 0 : Dr : -14: 0: 153: 69:Yes : Ok : Ok : 41 :26-05-05:620C? :Selfscan module
B9: 1 : Dr : -46: 0: 153: 69:Yes : Ok : Ok : 41 :26-05-05:620C? :Selfscan module
BC: 0 : Dr : -14: 0: 222: 70:Yes : Ok : Ok : 38 :26-05-05:620C? :Selfscan module
BC: 1 : Dr : -46: 0: 222: 70:Yes : Ok : Ok : 38 :26-05-05:620C? :Selfscan module
FD: 0 : Dr : -14: 0: 292: 64:Yes : Ok : Ok : 05 :26-05-05:620C? :Selfscan module
FD: 1 : Dr : -46: 0: 292: 64:Yes : Ok : Ok : 05 :26-05-05:620C? :Selfscan module
FB: 0 : Dr : -8: 0: 456: 32:Yes : Ok : Ok : 6C :/WRONG/ :620C? :Selfscan module
FB: 1 : Dr : -40: 0: 456: 32:Yes : Ok : Ok : 6C :/WRONG/ :620C? :Selfscan module
E6: 0 : Dr : -13: 0: 469: 32:Yes : Ok : Ok : D0 :26-05-05:620C? :Selfscan module
E6: 1 : Dr : -45: 0: 469: 32:Yes : Ok : Ok : D0 :26-05-05:620C? :Selfscan module
E7: 0 : Dr : -14: 0: 356: 32:Yes : Ok : Ok : EE :28-06-05:620C? :Selfscan module
E7: 1 : Dr : -46: 0: 356: 32:Yes : Ok : Ok : EE :28-06-05:620C? :Selfscan module
BE: 0 : Dr : -8: 0: 488: 21:Yes : Ok : Ok : 8F :26-05-05:620C? :Selfscan module
BE: 1 : Dr : -40: 0: 488: 21:Yes : Ok : Ok : 8F :26-05-05:620C? :Selfscan module
B8: 0 : Dr : -9: 0: 490: 8:Yes : Ok : Ok : 99 :28-06-05:620C? :Selfscan module
B8: 1 : Dr : -41: 0: 490: 8:Yes : Ok : Ok : 99 :28-06-05:620C? :Selfscan module
BF: 0 : Dr : -9: 0: 498: 8:Yes : Ok : Ok : E0 :26-05-05:620C? :Selfscan module
BF: 1 : Dr : -41: 0: 498: 8:Yes : Ok : Ok : E0 :26-05-05:620C? :Selfscan module
FC: 0 : Dr : -7: 0: 505: 4:Yes : Ok : Ok : BA :26-05-05:620C? :Selfscan module
FC: 1 : Dr : -39: 0: 505: 4:Yes : Ok : Ok : BA :26-05-05:620C? :Selfscan module
EE: 0 : Dr : -9: 0: 506: 4:Yes : Ok : Ok : 3E :26-05-05:620C? :Selfscan module
EE: 1 : Dr : -41: 0: 506: 4:Yes : Ok : Ok : 3E :26-05-05:620C? :Selfscan module
E1: 0 : Dr : -33: 0: 0: 510:Yes :Error: Ok : 6D :29-06-05:06BB? :Selfscan module
E1: 1 : Dr : -65: 0: 0: 510:No : : : : : :Selfscan module
E2: 0 : Dr : -34: 0: 0: 510:Yes :Error: Ok : AC :13-10-02:6000? :Selfscan module
E2: 1 : Dr : -66: 0: 0: 510:No : : : : : :Selfscan module
E3: 0 : Dr : -35: 0: 0: 510:Yes :Error: Ok : 68 :26-05-05:06BB? :Selfscan module
E3: 1 : Dr : -67: 0: 0: 510:No : : : : : :Selfscan module
E4: 0 : Dr : -36: 0: 0: 510:Yes :Error:Error: 55/EA :28-06-05:..... :Selfscan module
E4: 1 : Dr : -68: 0: 0: 510:No : : : : : :Selfscan module
E5: 0 : Dr : -37: 0: 0: 510:Yes :Error:Error: B7/28 :26-05-05:R.9C. :Selfscan module
E5: 1 : Dr : -69: 0: 0: 510:No : : : : : :Selfscan module
E9: 0 : Dr : -38: 0: 0: 429:Yes :Error: Ok : 76 :26-05-05:620C? :Selfscan module
E9: 1 : Dr : -70: 0: 0: 429:No : : : : : :Selfscan module
CONFIGURATION MODULE (02)
SA Copy num Location State
0 c: -2 H: 0 Ok
1 c:-34 H: 0 Ok
HDD Identify
Model................................... : WDC WD400BD-75LRA0
Serial number........................... : WD-WMAMC5060128
Master-password
Set..................................... : No
User-password
Security level.......................... : High
Log DCM (C5)
0 c: -3 H: 0 Ok
1 c:-35 H: 0 Ok
offset head)| | HE 44
WAY : 8, D (0 offset head)| | WDB
: 0, 7, F, Y (0 offset head)| | WDB-
HBMT: M, N, P ZR89: U (0 offset head)| +-----
PostPosted: November 21st, 2007, 10:06
Correct Felix. There are two options to solve this:
1 Regenerate translator if the modules can be rewritten; if this fails you can first try to write all 0's to the location of these modules and retry.
2 Hotswap
1 can be risky, 2 should not be a problem
Best regards,
Dobre
Murphy was an optimist
PostPosted: November 21st, 2007, 10:42
Thank you, but rewritting the translator wouldnt this erase the customers data as well?
PostPosted: November 21st, 2007, 11:27
In normal conditions not, since you base yourself on the plist in the drive; but safer is to copy the neccessary modules to another drive, regenerate the translator there and then do hotswap. Then there is no risk.
Dobre
PostPosted: November 21st, 2007, 11:38
Ok thank you I will try this.
Users browsing this forum: No registered users and 128 guests
