 Post subject: PCB Swapping list for DiamondMax Plus 9
PostPosted: March 10th, 2008, 15:29
Hello gurus,
on a Maxtor HDD the motor IC has smoked!
Thiese are the data of the dead HDD:
YAR41BW0 K,M,B,D
S/N: Y3594P8E
6Y 120 L0 03 26 11
Agere Ardent C8-C1
M6FYA
Y3594P8E FY03A
I have also these DiamondMax Plus 9, and I would like to know if I have the chance of a PCB swapping, without buying a new PCB.
Disk #1:
YAR41BW0 K,M,G,A
S/N: Y47J5A4E
6Y 160 P0 04 28 11
Agere Ardent C8-C1
M8FYB
Y47J5A4E FY04A
Disk #2:
YAR41BW0 K,G,G,A
S/N: Y466TAJE
6Y 160 P0 04 28 11
Agere Ardent C8-C1
M8FYB
Y466TAJE FY04A
I have also some DiamondMax 10 and 8, but I think they aren't good for PCB swapping!!!
tnxxx
carlitos
 Post subject: Re: PCB Swapping list for DiamondMax Plus 9
PostPosted: March 10th, 2008, 16:09
Post a pic of the PCB (patient)
PostPosted: March 10th, 2008, 16:13
of the broken one?
PostPosted: March 10th, 2008, 16:27
File comment: PCB smoked motor IC
File comment: Top Sticker
Tnx
carlitos
PostPosted: March 10th, 2008, 20:55
Hi!
Any of those boards will match your burned board.
www.datarecoveryne.com
PostPosted: March 10th, 2008, 21:06
harddrivespecialist wrote:
Hi!
Best to migrate the EEPROM from your PCB to the donor to ensure compatibility.
Jon
http://www.datasaversllc.com
PostPosted: March 10th, 2008, 22:13
both should be good.
PostPosted: March 11th, 2008, 2:43
Hi!
Jon
the patient PCB does not have external flash ROM...
but the others should be working...
PostPosted: March 11th, 2008, 4:11
Yep, should be good.
Go for it.
Your patient does not have external EEPROM.
PostPosted: March 11th, 2008, 5:06
Ok, thanks to all!
I will try the 2 PCB and I will inform you about the results. :)
Can you explain me what you said? Is the esternal flash ROM the chip where the firmware is stored? Where it should be located? In my case where the firmware is stored?
tnx
PostPosted: March 11th, 2008, 5:19
before you put new pcb on HDD
you must check that HDA is ok !!!
IF HDA is shorted the new pcb could be burnt also .....
Spasavanje podataka
PostPosted: March 11th, 2008, 5:30
Thank you gismon.
In my case, how can I check this with the multimeter?
PostPosted: March 11th, 2008, 11:46
Hi
there was a topic about this matter about a year and a half ago...
PostPosted: March 11th, 2008, 18:28
:( :? RESULTS! :( :?
I have checked and my HDA should be ok. Pin 3 is a GND and pin 4 & 5 aren't 0 Ohm with GND.
So I have swapped the PCB with the first donor: the HDD spins-up but after 1-2 seconds I hear a noise like a vibration of the arm onto the case. I have immediately powered-off the HDD and I have restored the donor HDD with its PCB. It is still working! :lol:
Exactly the same is happened with the second donor HDD.
Any suggestion?
Is this a wrong matching or.....?
tnx guru!
carlitos
PostPosted: March 11th, 2008, 19:08
Sounds like you have a head and/or preamp failure. :-(
Time to admit defeat and send to a pro.
PostPosted: March 12th, 2008, 2:56
Other sounds will be appreciated! :)
carlitos
PostPosted: March 14th, 2008, 0:19
U should check the ATA registers too what did u get, BSY reach´s DRDY DSC? knocks how many knocks , if knocks, maybe that shortcut damaged the Preamplifier u need to send to a DR company on that case where are u based?
Best Regards
PostPosted: March 16th, 2008, 14:23
Sorry, I have not understood. Anyway I don't want to make the donor controller unusable, trying it againon the dead hdd. Are you sure (100%) of the compatibility of the donor board with the dead hda?
Could be a wrong matching?
Tnx to all!
Carlo
Users browsing this forum: No registered users and 76 guests
