 Post subject: Sector 0 recovery
PostPosted: March 20th, 2008, 3:39
hi All,
i am having problem with my WD WD250JB-32EVA0, PCB=2060-001179-003 REV A.
The sector 0 of the hard drive is unreadable, i already try few software to recover and fix sector 0.
1)active@partition recovery ===failed
2)final data= failed
3)fdisk /mbr =failed
This the only model we had in stock, if we replace the pcb of this boards,what would the compatible
pcb boards?
thanks,
 Post subject: Re: Sector 0 recovery
PostPosted: March 20th, 2008, 3:44
Are you trying to recover data, or just get the drive usable?
PostPosted: March 20th, 2008, 3:47
i am trying to recover my data on this drives. this drives has 3 partition on it.
PostPosted: March 20th, 2008, 5:45
But all the drive reads ok except from sector 0 ?
PostPosted: March 20th, 2008, 6:24
yes,all is okey except sector 0.
PostPosted: March 20th, 2008, 6:27
I'm not familiar with the software you used. Try to run r-studio to see if you catch any partition.
PostPosted: March 20th, 2008, 23:53
As recommended, R-Studio is definetely a professional tool.
It does its work neatly.
I use it most of time for Logical Recoveries...
-RDS.
PostPosted: March 21st, 2008, 2:30
Download the free R-studio and run a complete scan. It should have no problem finding the partitions. I use it all the time for these types of problems. Best bang for your buck!
http://www.r-studio.com/
TestDisk 6.6 is a free tool and works really well. The only drawback is that it runs in a windows dos screen and is not that user friendly.
http://www.cgsecurity.org/wiki/TestDisk_Download
PostPosted: March 21st, 2008, 10:33
I don't know if this will help, I han't had time to test it. But it looks like it might a unfull tool.
roadkil's bootbuilter
http://www.roadkil.net/bootbuild.html
good luck.
