Post new topic Reply to topic  [ 47 posts ]  Go to page 1, 2, 3  Next
 Post subject: Maxtor DiamondMax Plus9 YAR41KW0 pcb question
PostPosted: August 24th, 2008, 11:27
First the info about the drive
Model: Maxtor DiamondMax Plus9
Code: YAR41KW0
sn:Y2CY6RJC
tla: 6Y080L042B411
Big chip on PCB: 040111300
I noticed it made a noise that it had a hard time getting to spin. So I bought a new drive and started copying my files. Windows didn't see the new drive so I took the old one out. Then I was stupid enough to re-connect the drive while the computer was on. Yea, I know. Don't laugh at me.
Now it don't do anything anymore. So, most likely I fried the PCB.
I went looking on eBay and found an exact matching PCB. Same model nr, firmware etc... Only difference is that there is a little extra chip on the board that my drive doesn't have.
See image:
I profesionally highlighted the chip I'm talking about.
How big is the chance that this will work?
 Post subject: Re: Maxtor DiamondMax Plus9 YAR41KW0 pcb question
PostPosted: August 24th, 2008, 14:34
It wont work , u have to find pcb with same pcb no like F4FYA .
PostPosted: August 24th, 2008, 14:45
But that's the problem. I can not find it anywhere after spending a good two hours on the internet. ...and I'm pretty good at finding stuff.
PostPosted: August 24th, 2008, 15:29
I am able to repair the drive but can't sell the PCB... :( grunt...
PostPosted: August 24th, 2008, 15:37
Hello
You need to find matching pcb with the same 5 letter code, what you have cut out from the photo.
If you have no access to this version, you can safely try to find another.
You need to match these letters exactly: xxxYx.
Your drive family code is the Y, this is important.
Additionally, use Diamondmax Plus 9 pcb-s only!
Don't need to care about the external little 8 pin ee, what you have marked...
You have only 3 choice:
1. will work.
2. will knock.
3. damaged pcb will burn your preamp (to avoid this, look closely the Q500 part, if it is burned, or damaged, don't use this board! Of course, better if you can measure it....)
4a. your preamp already dead, the drive will knock
4b. your preamp already dead, and will burn the Q500 too on the new pcb.
If you unsure about this, try to find a pro close to you.
Regards,
Janos
PostPosted: August 24th, 2008, 17:09
What's the ROM version?
e.g. F4FYA like Rameez says
PostPosted: August 27th, 2008, 8:01
Where can I find the ROM version you are talking about?
Thanks for the help so far.
PostPosted: August 27th, 2008, 8:05
1 - rom copy in SA
2 - read POKER chip for checksum.
PostPosted: August 29th, 2008, 19:06
I'm sorry, but that is Chinese to me. I'm a noob compared to you guys if it comes to hard drives.
PostPosted: August 30th, 2008, 1:25
Without special tools it is impossible...
PostPosted: September 1st, 2008, 9:38
Really? Someone told me all it takes is to replace the PCB is a screwdriver and some basic knowledge about electricity.
PostPosted: September 1st, 2008, 10:06
I was talking about firmware not remove a PCB, for this you only need a torx bit.
PostPosted: September 5th, 2008, 12:02
Is there a guide or how-to somewhere on the internet? I don't want to ruin the new one as well.
PostPosted: September 5th, 2008, 12:27
You did not mention your PCB NO...
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: September 5th, 2008, 12:34
What is that and where do i find that?
I installed the new PCB anyway, and now it starts to spin. But it makes a weird sound. I'm uploading a video to YouTube at the moment. I'll post it in a minute or two
PostPosted: September 5th, 2008, 12:43
Another one bites the dust... I give up.
PostPosted: September 5th, 2008, 12:47
the ROM did not match with the new pcb. thats why sound coming............ (if the problem still on the PCB)
SEE at the top of the PCB. you will see a 5 digit number. thats the pcb no. the number is like: F4FYA
__________
THANK YOU
SHAHI
http://www.youtube.com/watch?v=EesqM02Cbls
Here it is. I don't hear any rattle or clicking sounds when tilting the HD.
PostPosted: September 5th, 2008, 13:16
on the old one there is a sticker that says N2FYA, but the new one doesn't have this sticker.
PostPosted: September 5th, 2008, 16:19
Please help me
