Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: SAMSUNG KLM1G1CEHC-B101 (153FBGA)
PostPosted: July 10th, 2015, 8:08
We have one of the following 153 BGA chips in on a voice recorder. The voice recorder has failed, and deleted data is required from the chip. Consequently chip removal is required.
As per:
http://flash-extractor.com/forum/viewtopic.php?t=6161
We do not have the adapter for this chip and some of contacts I have in the DR industry do not hold it either as it is a rare model of chip to receive in. Acquiring the correct adapter for what is likely to be a one off job is not useful in this case.
Does anyone in the UK have the appropriate adapter? If so I can pass on your details to the customer.
Regards,
John
0161 408 4857
 Post subject: Re: SAMSUNG KLM1G1CEHC-B101 (153FBGA)
PostPosted: July 10th, 2015, 12:58
this is eMMC chip. you can read over SD card reader. just solder a little bit pin.
PostPosted: July 11th, 2015, 12:33
plus others :)
• MultiMediaCard System Specification Ver. 4.3 compatible (Boot operation is supported)
• Full backward compatibility with previous MultiMediaCard system ( 1bit data bus, multi-moviNAND systems)
• Data bus width : 1bit(default), 4bit and 8 bit
I think this is the datasheet, it may help.
201144131450191.pdf [332.27 KiB]
Downloaded 962 times
The files or data image may be tricky to get back, but would be an interesting case
The embedded flash mangement software or FTL(Flash Transition Layer) of moviNAND manages Wear Leveling, Bad Block Management and ECC. The FTL supports all features of the Samsung NAND flash platform and achieves optimal performance.
Not sure how much of this is reverse engineered already.
PostPosted: July 11th, 2015, 15:04
It could be easier and cheaper to find someone to repair the voice recorder. I could at least help you with some rudimentary checks.
PostPosted: July 11th, 2015, 20:43
I agree with fzabkar
PostPosted: July 12th, 2015, 10:20
Hi there,
Thanks for the reply. In this case the customer requires deleted data from the voice recorder. This was deleted shortly before the voice recorder failed. There is an 'erase' button which is quite prominent and it will format the device if depressed.
This particular voice recorder has no USB interface so there would not be a straight forward way to get the device into a mass storage mode to attempt the recovery of the deleted files.
Given what you have noted regarding this chip being eMMC and wiring in as per a SD I wonder if the areas I have highlighted in red on the attached image are likely to be leading into the appropriate pins for the SD connection?
0161 408 4857
PostPosted: July 12th, 2015, 14:31
The SAMSUNG moviNAND is an embedded MMC solution designed in a BGA package form. moviNAND operation is identical to a MMC card and therefore is a simple read and write to memory using MMC protocol v4.3 which is a industry standard. moviNAND consists of NAND flash and a MMC controller. 3V supply voltage is required for the NAND area (VDDF) whereas 1.8V or 3V dual supply voltage (VDD) is supported for the MMC controller.
You don't need to remove the chip. You only need to remove the daughter PCB that it sits on. Just treat the daughter PCB as an MMC card.
ISTM that the chip is configured in 4-bit mode with a single 3.3V supply. I would confirm that the +3.3V and Ground pins are correctly identified by measuring their voltages in-circuit.
The order of the data pins (DAT0 - DAT3) is not clear to me, but I would expect that they would be sequential. AFAICT, you won't damage anything if you get the order wrong.
Measure the resistance of the CLK resistor. That should confirm the identity of the CLK pin.
BTW, the model number of the voice recorder may help us to locate a service manual and/or a circuit diagram.
PostPosted: July 13th, 2015, 3:28
being on a daughterboard I think is a bonus, interested to see how you go after following fzabkars advice. Nice to potentially see eMMC used properly as intended.
PostPosted: July 13th, 2015, 3:40
Do you think there is any possibility of sending a data destructive command to the eMMC if the DATA pins are wired in the wrong order?
PostPosted: July 13th, 2015, 10:07
Arviaka is actually working on an almost identical chip for me right now. Only the one I had was from a Huawei phone.
PostPosted: July 13th, 2015, 15:24
ISTM that this job is trivial insofar as retrieving the raw data is concerned. The OP just needs to connect 8 wires from the daughterboard to a card reader that he could probably find on eBay for $10. I can't imagine that the Huawei phone would be that much different in principle. The file system and audio format might present additional challenges in both cases, though.
I could have been more helpful if I had a circuit diagram, but the OP appears to want to keep the model number a secret. AFAICT, the voice recorder is a Japanese design (Panasonic or Sanyo, possibly Sony) and was manufactured in late 2010.
FWIW, here are the datasheets for some of the power control ICs:
MTM862270LBF, Panasonic, N-ch MOSFET, RDSon 80mohm, marking JF, 20V, 2.2A, WSSMini6-F1 package:
http://www.semicon.panasonic.co.jp/ds4/MTM86227_E.pdf
http://www.maoye-smd.com/canshu/pdf/201 ... M86227.pdf
XC9103D091Dx, Torex Semiconductor, step-up DC-DC converter, no current limit, 0.9V feedback, 100kHZ, marking 6D091, USB-6P package:
http://www.torex.co.jp/english/products ... 3~9105.pdf
XC6209D28ADx, Torex Semiconductor, 2.8V LDO regulator, 150mA, USB-6P package, marking 09D28:
http://www.torex.co.jp/english/products ... 209_12.pdf
http://www.torex.co.jp/english/products ... XC6209.pdf
The "VHW" IC appears to be a power switch of some kind, with what looks to be a slow start feature. AFAICT there should be +3.3V on either side of it.
PostPosted: July 13th, 2015, 23:08
PostPosted: July 14th, 2015, 5:21
If embedded controller inside eMMC chip works, data recovery is not so hard. But if controller not work, it is problem, we must find pinout directly to nand.
PostPosted: July 14th, 2015, 16:02
The order could be ascending or descending.
PostPosted: July 26th, 2015, 14:53
Thanks for all the replies, currently working on this one - definitely a job for a wet Sunday afternoon. Will be in touch with results shortly.
0161 408 4857
PostPosted: July 26th, 2015, 15:45
I have the daughter board wired into a bread-board. At the moment I can't get a hardware ID. Regarding the order of the DAT, there are a total of 24 combinations in order. I have not started working my way through these methodically on the hope that someone else might have one of these working. I shall carry on working through the possible combinations tomorrow.
Thanks,
J
0161 408 4857
PostPosted: July 26th, 2015, 16:33
4 bits give 16 combinations, not 24.
http://www.google.com.au/search?q=2%5E4
Why not just tell us the model number of the voice recorder? Then someone might know if they have "one of these".
PostPosted: July 26th, 2015, 17:05
Sorry I had forgotten to, model:
Olympus VN-750.
Best regards,
J
PostPosted: July 26th, 2015, 18:23
Sorry, another brain fart. The number of combinations is 4 x 3 x 2 x 1 = 24.
BTW, I checked my usual sources for service manuals and circuit diagrams, but I found nothing.
If at all possible, you could try to trace the data pins back to the microcontroller. The order of the pins should be sequential there.
PostPosted: July 27th, 2015, 10:30
Olympus VN-750 1GB Digital Dictaphone - £14.99 at Argos:
http://www.hotukdeals.com/deals/olympus ... os-1801429
... or £24.99 at Amazon:
http://www.amazon.co.uk/Olympus-VN-750- ... B007UPLST0
Users browsing this forum: Majestic-12 [Bot] and 63 guests
