 Post subject: Wise CFast 2.0 256GB
PostPosted: September 13th, 2023, 8:01
Hello guys!
I have this Wise CFast 2.0. It is getting voltage and with short the PC3K is recognize the SSD with 4MB...
I ordered a new one to check the scematic layout but its a different PCB...
My problem is that i want to get the data, but the pc is not recognize the SSD.
I am not sure if its the controller or the NAND chips... i didnt find any shorts.. does anyone have any experience with a case like this?
Is reballing an option?
Thank you guys!
 Post subject: Re: Wise CFast 2.0 256GB
PostPosted: September 13th, 2023, 9:26
http://www.flash-extractor.com/library/JMF/JMF670/
http://flash-matrix.com/
PostPosted: September 13th, 2023, 9:44
csava, Hello, how does this helping me?
PostPosted: September 13th, 2023, 10:12
The only solution for this controller chip is chip off
PostPosted: September 14th, 2023, 1:42
You need read chip at external reader and assembly the data. Usually swap or reballing not help, just makes bigger degradation of memory modules.
PostPosted: September 14th, 2023, 3:09
csava, arvika, thank you guys! I work with the PC3K Flash.. i hope they have a solution for it...
PostPosted: September 14th, 2023, 12:10
I'm sceptic, but you can try ;)
PostPosted: September 15th, 2023, 3:14
arvika, anything else to recomand?
PostPosted: September 15th, 2023, 10:03
For this case probably Flash Extractor or VNR will be the best.
Users browsing this forum: No registered users and 21 guests
