 Post subject: Kingspec Raymx RM1135 - No life signal
PostPosted: October 9th, 2023, 12:47
Hello guys, good day.
I'm struggling with a SSD Kingspec Raymx RM1135, with no life signal. It does't turn on any status register when powered.
Made some measurements. Both three 6 pin mosfets are receiving 5.1V and delivering 4.7V (U17 and U4) and 1.1V (U18) on outputs.
Don't know what would be the next steps. If someone could please help me. Thank you for any answer.
 Post subject: Re: Kingspec Raymx RM1135 - No life signal
PostPosted: October 9th, 2023, 13:58
You have measured the inputs. Now measure the outputs.
PostPosted: October 9th, 2023, 15:21
fzabkar, Thanks for your reply.
Those are the outputs
PostPosted: October 9th, 2023, 15:42
L1, L4 and L6 are the outputs. If you really are measuring 5V at the outputs, then the converter ICs are faulty.
PostPosted: October 19th, 2023, 17:12
Hello guys. I'm comming only to give a feedback.
I've found that one capacitor was shorted and switched it from another equal ssd, and it worked flawless.
Thank you so much fzabkar, as allways a very kind help.
PostPosted: January 24th, 2024, 9:46
amigo qual o capacitor,to tendo o mesmo problema
PostPosted: May 22nd, 2024, 1:13
i have same as this 2tb.. bios and windows detecting properly, problem is ssd showing multiple size (1GB+,2GB, 4GB, 8GB, 16GB, 1.8TB) 16 patitions unformated some unallocated space, over all not all accessible... (Hard disk Sentinel) application working on it, report is read Test 100% ok, write test 0% when i start write test ssd hide from every ware, like ghost. when i restart my computer, again showing same as before.... kindly tell me solution
PostPosted: August 15th, 2024, 5:57
Hi ,
Anyone knows safe mode short pins on this
Users browsing this forum: No registered users and 29 guests
