Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Samsung EVO 850 - workstation won't boot
PostPosted: January 7th, 2023, 12:47
Lardman wrote:
silcontool wrote:
going to play with the board before I destroy it :)
Please don't just destroy the drive when you're done with it. As Pepe says, as an industry we lack research and development drives and faulty material we can actually work on rather than client cases. Without doing this recovery prices will always remain high. If it's just going in the bin consider donating it to a lab for research instead.
While I agree with your sentiment in regard to destroying drives, I ask you, since when has any DR shop shared the results of their reverse engineering, aka "research"? Certainly not @pepe. In reality, nobody benefits except the receiver of the donation.
PostPosted: January 7th, 2023, 13:42
i would argue with the above a bit (it seems to be a habit of mine :) . When somebody becomes able to recover something due to research, both he/she and his/her clients benefit from the result.
Anyway, i would be happy to play on that damaged thing...
PostPosted: January 9th, 2023, 4:39
This is not true.
Often people who do RE on unknown devices or difficult problems of known devices will share/sell their results with/to other DR labs that they trust. The clients of these DR labs will also benefit by having their data recovered.
PostPosted: January 18th, 2023, 11:46
So I put the drive in a sata USB enclosure Device Manager does show the enclosure but disk information is blank there.
Diskmgr apparently showed an unknown disk partition of size 465GB and prompted to initialize it which I "cancel". So I guess the drive is okay but may have some problem with the boot partition ?
PostPosted: January 19th, 2023, 6:54
btw, isn't that a socialist point of view, where everything must be common property? There is a difference between donating a damaged unit for research and spending weeks/months on reversing how it works and developing a solution to an actual problem.
btw, i offered the owner that if i can get around the problem i would give him the data for free, of course without any deadline, etc.
PostPosted: January 19th, 2023, 7:03
@silcontool:
i would also suspect your ssd is accessible through the interface, try to image it, then some logical recovery sw.
perhaps you could show us the first sectors with winhex (needs admin rights to access the physical device).
PostPosted: January 19th, 2023, 7:14
I've them in that state but without the ability to get UA, they go bsy at read.
PostPosted: January 19th, 2023, 7:32
yes, that's also possible... we'll see
PostPosted: January 19th, 2023, 16:33
I merely asked a question, and I ask it again, do you share the results of your RE outside of your special clique? Of course you don't, so the only beneficiary of any donation would be you. I'm not making a value judgment, I'm simply stating a fact. In other words, I'm not saying that you should share, I'm simply saying that you don't. And I don't have a problem with that when the work is non-trivial.
PostPosted: January 20th, 2023, 0:30
pepe wrote:
@silcontool:
I will try "winhex" hope the trial version is good enough to get some drive information besides possibly creating the drive image. I don't know about a logical recovery s/w which can be used for retrieving though. Any suggestions please?
Looking online...so far I haven't found one I can trust other than "ddrescue".
PostPosted: January 20th, 2023, 4:55
@silcontool - Grab a copy of hddsuperclone from www.hddsuperclone.com there's an iso to create a bootable thumb drive from, it contains most of the tools you will need. Although I suspect the drive will lock up as soon as you access data.
PostPosted: January 20th, 2023, 5:40
this is what i am arguing with. Clients also benefit from jobs being done. And i made a fair offer to the one making donation, so i should not be the only beneficiary.
PostPosted: January 20th, 2023, 13:32
I would make a donation to Ace Laboratory. Their clients are the entire data recovery community and, by extension, the entire data recovery clientele.
PostPosted: January 20th, 2023, 14:27
If we only had what Pc3k supports, we were in trouble...
btw, you seem to be a bit incoherent with yourself, sometimes you ban the DR community because nobody does original research, and only clicking buttons, then if somebody does, you accuse him of being the only one who swallows the profit.
you know, competition is what drives the market and it is good for the clients as well. If competition is killed by one member of the market by disclosing everything, that would harm exactly those who do something on their own. Ace's interest is not to implement everything as it is available, but to keep TS (=update) going, so i think they schedule things to keep the interest for the updates.
btw, there are a lot of solutions that can't be simply included into their utils coz of requiring other tools and deeper knowledge.
PostPosted: January 20th, 2023, 16:13
When I first came to this forum, someone contacted me privately and said that, if I kept quiet about TVS diodes, they would let me in on other trade secrets. That set the tone of the whole data recovery business for me. Now we have someone proposing a secret cabal along those same lines.
https://forum.hddguru.com/viewtopic.php?f=3&t=43008
PostPosted: January 20th, 2023, 16:21
members should be judged by their own deeds and not by one guy. Judging a whole community by one is not wise i believe.
regarding what you linked, are you serious about we are supporting this????
PostPosted: January 20th, 2023, 23:25
Here is the "dmesg" and "lshw" result of the drive. Tried "hddsuperclone" but the "analyze" failed 100% probably because it failed to read from the drive. Is there anything else I can try?
I came across a thread of @fzabkar on "hddoracle" about "In-circuit recovery of SSD with weak NAND". I'm going through it right now.
File comment: dmesg
dmesg-ssd.txt [28.73 KiB]
Downloaded 407 times
PostPosted: January 20th, 2023, 23:59
All that is saying is that it tried to read from the first and last physical sectors, and it failed every time.
PostPosted: January 21st, 2023, 13:46
Ok trying to understand the problem with the drive. Wondering how come the ssd size at least was reported when it is inside a USB based enclosure and it wasn't even detected while directly connected on the SATA port of the LSI controller I've in my PC. As fzabkar said, it is very well that one of the NANDs is bad which is probably making the controller not allowing the access. Then the question is why the firmware is not allowing the access to the good NANDs ? probably f/w is not written for that ?
Going to check the voltages and get to the UART.
PostPosted: January 21st, 2023, 15:22
it would be useless because of data being 'interlaced', throughout multiple nand chips.
Users browsing this forum: No registered users and 17 guests
