shorting point Samsung S4LN062
Posted: June 17th, 2019, 21:16
by TerraNova
Anyone know the shorting point or work around for Samsung 850EVO S4LN062 i think its Samsung PM871 Lenovo
Either the terminal is locked or not supported by PC3000 ssd?
Re: shorting point Samsung S4LN062
Posted: June 18th, 2019, 1:48
by sourcerer
Yes, red should be the shorting point, and yellow the terminal. What is the behaviour you get? Are all other voltages correct? Do the chips get warm or hot when powered?
Posted: June 18th, 2019, 2:25
by fzabkar
Posted: June 18th, 2019, 2:48
by TerraNova
Just get an error from PC3000 shorting is not successful, i think this is terminal lock
Posted: June 18th, 2019, 6:08
by fzabkar
TerraNova wrote:Just get an error from PC3000 shorting is not successful, i think this is terminal lock
How can you say that without measuring anything?
Posted: June 18th, 2019, 8:42
by sourcerer
Does it come up on SATA when you short the 2 pins and power it up?
It should provide a RAM-disk on SATA with approximately 80% of the RAM size as the disk size.
