How to flash latest firmware (D417) on SanDisk LT0200WM disk
Posted: January 26th, 2024, 11:30
Is there any way (or any paid way) to get these disks flashed to D417 or the latest usable firmware that doesn't have the 40K hour bug?
[0:0:21:0] disk SanDisk LT0200WM P405 /dev/sdd /dev/sg2
[0:0:22:0] disk SanDisk LT0200WM P405 /dev/sde /dev/sg3
[0:0:23:0] disk SanDisk LT0200WM P405 /dev/sdf /dev/sg4
[0:0:24:0] disk SanDisk LT0200WM P405 /dev/sdg /dev/sg5
=== START OF INFORMATION SECTION ===
Vendor: SanDisk
Product: LT0200WM
Revision: P405
Compliance: SPC-4
User Capacity: 200,049,647,616 bytes [200 GB]
Logical block size: 512 bytes
LU is resource provisioned, LBPRZ=1
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Logical Unit id: 0x5001e82002806304
Serial number: 41968388
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Fri Jan 26 17:29:13 2024 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Enabled
=== START OF READ SMART DATA SECTION ===
Example of a dead drive
diskblaster2500:~/extract/payload # smartctl -a /dev/sdg
smartctl 7.2 2021-09-14 r5237 [x86_64-linux-5.14.21-150500.55.31-default] (SUSE RPM)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: SanDisk
Product: LT0200WM
Revision: P405
Compliance: SPC-4
Logical Unit id: 0x5001e8200280b4e8
Serial number: 41989352
Device type: disk
Local Time is: Fri Jan 26 17:29:43 2024 EET
device is NOT READY (e.g. spun down, busy)
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
Any possible solution?
Vendor: SanDisk
Product: LT0200WM
Revision: P405
Compliance: SPC-4
Device type: disk
Vendor: SanDisk
Product: LT0200WM
Revision: P405
Compliance: SPC-4
Device type: disk
