 Post subject: HTS541
PostPosted: September 5th, 2011, 6:28
I'm experiencing problems with an HTS541 drive.
The PC3000 cannot ID the drive and return that :
Loading modules table................................................. : Ok
Loading the table of "open" modules................................... : Error
Error :............................................................... : Error executing loading "open" modules dir command
I think that these modules are required for the initialisation of the HDD.
Can somebody help me with this ?
Lemmy
 Post subject: Re: HTS541
PostPosted: September 5th, 2011, 9:18
Probably some main modules are damaged.
Have you checked them?
Probably PSHT.
PostPosted: September 5th, 2011, 10:34
PSHT was damages but i was able to repair it. And the result is the same !
EDIT : DUMP is also damaged but importance is D so i didn't touch it !
Lemmy
PostPosted: September 5th, 2011, 10:43
You say that you repaired it.
So that means that one of the copies was good? Or did you rebuilt manually and copied it to the drive?
After power reset, can you read PSHT just fine in both copies?
DUMP doesn't matter.
PostPosted: September 5th, 2011, 10:49
Copy 0 and 1 are bad (unreadable sector) but Factory copy was good.
So I modified module RESF with the adress of PSHT of factory copy.
Am I wrong of doing that this way ?
EDIT : after power OFF/on, copy 0 is good and copy 1 and factory are bad !
Lemmy
PostPosted: September 5th, 2011, 11:00
Ok.
So if you have copy0 fine, even if you don't get an ID, you should be able to access LBA.
Have you tried it?
PostPosted: September 5th, 2011, 11:32
Yes i tried and it doesn't work !
Lemmy
PostPosted: September 5th, 2011, 11:43
So something is wrong with SA yet.
Are you sure when you changed RESF, you didn't shift any other modules?
PostPosted: September 5th, 2011, 11:58
I'll check that.
Anyway, I think I'll send an email to PC3000 support et post here what was the problem when i find it !
Lemmy
PostPosted: September 5th, 2011, 12:30
Another option can be also to relocate SA.
PostPosted: September 6th, 2011, 11:34
Copying user data right now...
Thanks to Ace support who showed me this topic http://acelaboratory.ru/forum/viewtopic.php?f=30&t=7186 (you have to be logged in)
Thanks to dmarques too.
Lemmy
PostPosted: September 6th, 2011, 12:40
Ok. SA relocation solved it :D
PostPosted: September 7th, 2011, 3:02
I wouldn't say it was just "SA relocation" like you would do it with the WD dir editor...
Lemmy
PostPosted: September 7th, 2011, 5:09
Glad you solved it anyway.
Users browsing this forum: No registered users and 100 guests
