 Post subject: WDEURS-63S48Y0 Sadle G6 How to Disable Heads?
PostPosted: May 1st, 2013, 12:50
Hey Guys, I'm hopeing someone can help me out.
I've got this WD Green which seems to belong to Sadle G6 family. However it does not seem possible on PC3k to edit RAM heads map for this model. When I attempt to edit head map in Kernel mode I get an error - RAM Range FFE00000 reading error, device error detected. I have never seen this model of drive before so perhaps it's normal but I'm not sure.
I'm wondering if this is a problem with my drive or if the utility just doesnt have the ability to edit RAM headmap on this drive. If editing heads map is not possible what the next best proceedure?
CDR Core Data Recovery
 Post subject: Re: WDEURS-63S48Y0 Sadle G6 How to Disable Heads?
PostPosted: May 1st, 2013, 13:24
Test a healthy G6 drive on your system. Still have this problem?
PostPosted: May 1st, 2013, 13:39
No problem editing heads map on any other G6. Mind you we dont have any other WD20EURS drives to compare against.
PostPosted: May 1st, 2013, 15:51
Why do you need to edit head map in RAM?
I don't think they like it if H0/1 are bad.
Users browsing this forum: No registered users and 111 guests
