 Post subject: This sub menu seems to be in another language.
PostPosted: September 7th, 2013, 1:49
This sub menu seems to be in another language. Anyone know what it says?
 Post subject: Re: This sub menu seems to be in another language.
PostPosted: September 7th, 2013, 7:30
yes: it says "you have four choices, make your best guess... Mwuhahahahaha!"
looks corrupted to me with so many graves accents umlauts and cedila :/
Kern
Голод не тётка!
PostPosted: September 7th, 2013, 8:29
try installing traditional chinese into windows, or Russian... or wherever the software is from. should display then you can google translate it.
PostPosted: September 7th, 2013, 9:37
It's Russian. You need to choose the proper font and then translate the result.
Hint: The second word translates to "engine".
PostPosted: September 7th, 2013, 10:23
Hint #2:
3. инициализация с новой картой
3. Initialized with the new card
PostPosted: September 7th, 2013, 11:33
As everyone has said you need have correct language to display the correct Cyrillic characters
PostPosted: September 9th, 2013, 0:32
I have the Russian language loaded and get the same thing. I tried contacting Ace by email, support ticket, and forum but nothing so far.
PostPosted: September 9th, 2013, 1:35
HI
Have u tried to Re-install software again...........
PostPosted: September 9th, 2013, 2:57
I think you may have to choose the Russian language in windows, the language bar IIRC, not just have it installed. Meaning everything is set to Russian. (if it is indeed the Russian language. I don't know Russian, is there more than one type of langage pack in the Russian language, like there is for different chinese variants?
I struggled getting a few Greek programs working at the school I support.
PostPosted: September 9th, 2013, 4:23
http://en.wikipedia.org/wiki/Windows-1252
http://en.wikipedia.org/wiki/Windows-1251
PostPosted: September 9th, 2013, 4:44
PM Sent....
Think Different (As apple)
:mrgreen:
PostPosted: September 9th, 2013, 17:01
Tell Ace that there appears to be a typo on the first line.
BTW, it's all about motor control, working with head maps and ROM, and adjusting capacity.
Also, Google's initial translation isn't always the most appropriate, so check the alternatives.
PostPosted: September 10th, 2013, 18:52
Can someone check their North American version to see if the WD 16-bit is messed up?
PostPosted: September 10th, 2013, 19:15
А Б В Г Д Е Ж З И Й К Л М Н О П Р С Т У Ф Х Ц Ч Ш Щ Ъ Ы Ь Э Ю Я
À Á Â Ã Ä Å Æ Ç È É Ê Ë Ì Í Î Ï Ð Ñ Ò Ó Ô Õ Ö × Ø Ù Ú Û Ü Ý Þ ß
а б в г д е ж з и й к л м н о п р с т у ф х ц ч ш щ ъ ы ь э ю я
à á â ã ä å æ ç è é ê ë ì í î ï ð ñ ò ó ô õ ö ÷ ø ù ú û ü ý þ ÿ
PostPosted: September 10th, 2013, 23:33
It says
1. Spin up/create (heads) map in ROM (doesn't make clear sense to me even that Russian is my native language, lol :), also it has a typo as was mentioned before )
2. Reading/editing/writing heads map
3. Initialize with new (heads) map
4. Correct(change) drive's capacity using module 0x42
PostPosted: September 11th, 2013, 3:10
Mine (not North American, though :P) is messed up as well, both UDMA and PCIe.
PostPosted: September 13th, 2013, 20:19
Thanks guys, Ace seems to be ignoring the topic for some unknown reason.
PostPosted: September 14th, 2013, 11:36
They don't use native English people as BETA testers, I'm never surprised when I find a messed up menu
