Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: LDR Maxtor 6L080L0 needed
PostPosted: December 3rd, 2008, 6:50
No help? :?:
:idea:
:mrgreen:
Нет ничего невозможного
PostPosted: December 3rd, 2008, 15:56
His bad modules 93 and 7b.
copy modules h2 view this blank!
I rewrites it in another hdd?
or how can I repair and access data?
PostPosted: December 4th, 2008, 3:58
Hi Sempre,
As far as i know module 93 is drive specific.
What you could try (i dont know if this works) is to read the module with each head (ignoring errors option) and then compare with a known good module to see if you can make any corrections by hand.
Hope this works.
Dobre
Murphy was an optimist
PostPosted: December 4th, 2008, 7:02
dobrevjetser wrote:
Hi Sempre,
Hope this works.
Dobre
I go to try! :mrgreen:
Thanks!!
PostPosted: December 4th, 2008, 8:08
which the function of the modules of h2?
PostPosted: December 4th, 2008, 13:20
93 is FMTI module it isnt specific u can copy from any hdd with same number of heads .
PostPosted: December 4th, 2008, 13:34
After the rewrite of it modulates 93 has that to make other actions to have access the data? :?:
for example to regenerate the translator…
:mrgreen:
PostPosted: December 4th, 2008, 14:20
this module is used in full size drives. it contains zone allocation tables and adaptive settings for each zone; therefore the module is essential for access to data. Tables of drive family specifications in chapter 9 indicate full size and half size families.
THANKS FOR HELP!!
PostPosted: December 4th, 2008, 14:30
MODULE 93 FMTI
IMPORTANCE Ad
"A- essential for a specific hdd: As - adaptive settings, Ad- translator tables. Replacement of the module with an identical module from another drive will result in the loss of reading/writting settings and data loss (e.g., adaptive data modules);" in MANUAL...
PostPosted: December 5th, 2008, 8:22
My friend,
:arrow: this deceived you! it is enough to verify…. that look that each hd has its modulates exactly 93 different being of the same family…
PostPosted: December 5th, 2008, 8:40
sempre wrote:
My friend,
LOOK RAMEEZ!
PostPosted: December 5th, 2008, 14:15
Sorry i forgot about this one .
Then u can repair this module by comparing .
PostPosted: December 8th, 2008, 10:15
Hi to all!!
Somebody already had some similar case or very similar in relation to this problem (it modulates 93 corrupted)? :?:
Or it has an idea of as to obtain to arrive hdd ties the data of this? :?:
:mrgreen:
Thanks advance!!
