 Post subject: Seagate 7200.9 ST3250624A
PostPosted: December 11th, 2008, 11:32
On DataEx. it could be read only in Mode - without CRC
in others mode very very slow...
On terminal there are:
Interface task reset
4096k x 32 SDRAM
TONKA15 - 1_Disk S.68 03-14-06 11:24
Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
Master
AT Er 00 Nwt Er 37 RdWr 0de5f.03.02ef
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.3.525 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 00de5f.03.02ef
CE Log ErrCode=37 LBA=105df0b2 Type=5 Add To Pending 105df0b2
AT Er 00 Nwt Er 37 RdWr 0de5f.03.02f0
Niwot: 9ff79ff7 b6 9ff79ff7.3.525 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 00de5f.03.02f0
CE Log ErrCode=37 LBA=105df0b3 Type=5 Add To Pending 105df0b3
AT Er 00 Nwt Er 37 RdWr 0de5f.03.02f1
DiskAccess ReadSector EC=43 at 00de5f.03.02f1
CE Log ErrCode=37 LBA=105df0b4 Type=5 Add To Pending 105df0b4
AT Er 00 Nwt Er 37 RdWr 0de5f.03.02f2
DiskAccess ReadSector EC=43 at 00de5f.03.02f2
CE Log ErrCode=37 LBA=105df0b5 Type=5 Add To Pending 105df0b5
AT Er 00 Nwt Er 37 RdWr 0de5f.03.02f3
etc
etc
etc.
Any idea ? What is it....?
Spasavanje podataka
 Post subject: Re: Seagate 7200.9 ST3250624A
PostPosted: December 11th, 2008, 11:51
Ace's UDMA can handle this in the utility settings in DE.
Best regards,
Dobre
Murphy was an optimist
PostPosted: December 11th, 2008, 11:56
Best regards,
Dobre
Please more details...
is it error on hdd ?
What is it ?
Spasavanje podataka
PostPosted: December 12th, 2008, 8:24
CE Log error
FW Issue, needs resolving with PC3000 or Salvation.
PostPosted: December 16th, 2008, 10:45
could anybody help ?
what shoud we do with pc3000 udma ...??
Spasavanje podataka
PostPosted: December 16th, 2008, 12:48
4096k x 32 SDRAM
Spin Ready
(P)PATA Reset
Master
etc
etc
etc.
The hdd byself its trying to add sectors to pending list lilke "Seltest process" like autoreasign process,
PostPosted: October 26th, 2011, 4:15
I've got similar problem.
SMART shows a few hundred bad sectors.
The problem is it scans well in MHDD (shows some UNC and S). Average speed is 40MB/s.
While making the clone (DMDE), copying speed is incredibly slow - 1MB/min.
The same result when using ATOF in MHDD.
Is there a way to speed it up ?
data recovery Poland
PostPosted: October 26th, 2011, 22:13
Windows is probably downgrading the transfer mode from DMA to PIO.
Try cloning with ddrescue from a Ubuntu Live CD or USB flash drive.
PostPosted: October 26th, 2011, 22:49
Windows has difficulty dealing with a deteriorated drive. Hence, why the drive works better/faster in MHDD.
As fzabkar suggestion implies, you have to work outside of Windows, where you are in control as oppose to Windows.
PostPosted: November 5th, 2011, 2:08
Do hdd head test first
if head write - read ok you can try T>T4E
PostPosted: November 14th, 2011, 19:44
this issue looks pending bug + weak heads; i faced it last week exactly on 7200.9 400Gb.
partially solved on pc3k, now i need to wait new heads to finish cloning.
Don't try to clone it without fixing it , or ur heads ( if left un-attended) will mechanically demaged the drive.
