 Post subject: Toshiba MQ01ABD050 BSY
PostPosted: June 13th, 2014, 14:40
Hi
Got this drive that can't ID...
After power on I get this:
Techno On............................... : Drive is not ready
Zone table.............................. : Zone table read error; Drive is not ready
G-List reading error.................... : G-List read error; Drive is not ready
CP Avalable............................. : 33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE ,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D 6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
The drive tries to calibrate (some very low noises) and sometimes can get Ready, other times, stay Busy.
Can this be only the G-list error?
I have tried to clean it, but I always get the drive Busy....
Thank You
ACELab partner
 Post subject: Re: Toshiba MQ01ABD050 BSY
PostPosted: June 13th, 2014, 17:04
Have you tried isolating Head Contacts ?
Data Recovery Pakistan
PostPosted: June 17th, 2014, 8:01
Yes, didn't helped...
ACELab partner
PostPosted: June 17th, 2014, 8:10
than most likely, media or head problem
PostPosted: June 17th, 2014, 8:29
The Toshiba hdd stay busy because of continuous reading of bad area (Bad sector ) and assign it. when the damaged sector is read able then the hdd shows you ready status, some time it take about 30 minutes to become ready. after ready clear G list and extract data by cloning through MRT or pc3000.
Some times head or sub zones are damaged that's why it stay busy fro about 30 minute.
Waqas Ali
PostPosted: June 17th, 2014, 13:12
This is a FW problem (translator...) If I read thru utility on PC3K I can access data. The problem is that I don't have DE....
Still working on it.
ACELab partner
PostPosted: June 17th, 2014, 15:02
Got it imaging finally eheheh
ACELab partner
PostPosted: June 23rd, 2014, 4:55
Are you sure this was translator issue?
Data Recovery Cape Town
PostPosted: July 1st, 2014, 5:32
Yes, the case was closed with 100% recovery.
At least with this solution I could get the data.
ACELab partner
