 Post subject: Ultrastar HUH721ALE600 PCB replaced but cant read sectors
PostPosted: January 7th, 2025, 2:54
hello i have this urgent case with broken pcb
iv changed the pcb. with a donor ...the HDD become ready but cant read any sectors!
do i also need to solder the ram IC on the hdd ? or the smooth IC? are the head adaptived in the ram IC?
 Post subject: Re: Ultrastar HUH721ALE600 PCB replaced but cant read sector
PostPosted: January 7th, 2025, 11:09
yeah, i suppose you need to transfer adaptives at the least.
would it be hard to post a pic about the pcb?
PostPosted: January 8th, 2025, 23:26
Hello Sir iv soldered back the ROMS to the original pcb and soldered back to the donor
now both HDD get ready but cannot access the sector ! im shocked
PostPosted: January 9th, 2025, 0:22
Did you dump the ROMs, or did you just solder them? In any case, could you dump all 4 ROMs? I have written a tool that can parse the contents.
PostPosted: January 9th, 2025, 0:36
Dear fzabkar thank you for your super fast answer
i just replaced the rom did not dumped! which tool do you use to dumb this type of ROM chip?
PostPosted: January 9th, 2025, 1:39
My software extracts all the firmware modules from a HGST ROM.
https://www.hddoracle.com/viewtopic.php?p=23963#p23963
PostPosted: January 9th, 2025, 2:17
how do i Run your Software Sir?
PostPosted: January 9th, 2025, 4:49
My tools run in a CMD window. They extract the components from your HGST ROM dumps. You need to dump the ROMs, then my tool will analyse your .BIN files.
PostPosted: January 10th, 2025, 3:39
thank you i will buy a proper adapter but im not sure my programmer can read it...
my programmer is GZUt one pro
http://www.dream-e.com/Pshow.asp?Pid=44
im planning to buy this adapter USON8-4X3-XG ^^ do you think is suitable??
https://www.aliexpress.com/item/1005007 ... e-home.0.0
may i ask ? in the case my programmer doesnt work is there any cheaper programmer you can suggest?
again sorry for milion of questions... im still a beginer
PostPosted: January 22nd, 2025, 23:29
excuse me Sir but im unable to use your amazing tool. is there any manual or video tutorial? sadly when i double click on the EXE nothing happened...
just in case this is my two rooms. how can i fix them?
https://drive.google.com/drive/folders/ ... sp=sharing
PostPosted: January 23rd, 2025, 0:18
Sir i could finally open your amazing tool with CMD .
i dragged the ROMs one by one on CMD and i the HEX editor opened automatically^^
should i save this two ROMs and write it on the CHIPs?
thank you for your patience
PostPosted: January 23rd, 2025, 0:25
does your tool repair the room atumatically or should i do anything on the rom? that appear ?
PostPosted: February 4th, 2025, 22:54
Sir does your tool repair the room atumatically or should i do anything on the rom? that appear ?
can you take a look at the rom backup?
PostPosted: February 5th, 2025, 2:58
No, it doesn't. And in your situation, it is not ROM issue. Same problem you get if connect only PCB. User area access is different story. Do you hear long double recalibration of you hard drive or it became ready within a second?
Angel Data Recovery
PostPosted: February 5th, 2025, 12:54
The OP damaged a good donor drive by using its PCB on the patient without a ROM transfer. Doesn't this imply that something was written to the donor ROM by the patient drive? I assume that the donor is still spinning.
PostPosted: February 5th, 2025, 14:43
or the preamp is dead and killed both pcbs...
PostPosted: February 5th, 2025, 15:17
Here is another thread where a donor drive was damaged after the OP messed about with ROMs:
https://forum.hddguru.com/viewtopic.php?f=1&t=44071
PostPosted: February 5th, 2025, 22:36
thank you for the kind answer
is bit long recalibration but not weird sounds
PostPosted: February 5th, 2025, 22:38
Sir i did the rom CHIP swap! both hdd are spinning! both hdd had data access before the swap
PostPosted: February 5th, 2025, 22:40
thank you for the message Sir
does swap the rom chip kill the preamp? both HDD are spinning and get ready without any weird sound
Users browsing this forum: No registered users and 28 guests
