Forum rules
 Post subject: Hi, I'm new here, and need help.
PostPosted: November 14th, 2008, 12:13
But don't we all......
I have a Samsung SP0802N and need a schematic for the main board. Any ides where I can find one?
I put 16v through it by mistake and blow a SMC, the one to the left of the middle screw. looking at the drive with the spindle cable to the top.
So, can about help here?
TIA
Andy
 Post subject: Re: Hi, I'm new here, and need help.
PostPosted: November 14th, 2008, 12:22
Post a pic
PostPosted: November 14th, 2008, 12:35
OK, here goes.
In the main pic. you can see where it sits, just to the left of that PK screw, the bottom pic is the SMC. I think it could be a diode, maybe a votreg. Anyway, what do you think? I have just DLL Palo_SVC_Manual_Eng.pdf which is great, but, does not show any components.
PostPosted: November 14th, 2008, 12:46
Pic is blurry, but seems it is a power diode. You should be able to simply 'replace' this with one from a donor PCB, no need to worry about compatibility.
PostPosted: November 14th, 2008, 13:27
hello,
i am sure that is diode.
data recovery service[/b]
PostPosted: November 16th, 2008, 6:54
Thanks Guys, that's what I was thinking, Diode, will have a look through the c&^p I have as see if I have one, failing that I will pop over to RS, I doubt if Maplin would have one.
I'll let you all know if I fix the problem.
Andy :)
Users browsing this forum: No registered users and 14 guests
