 Post subject: WD2500JS-00MHB0 - U12 is dead
PostPosted: February 15th, 2011, 17:25
Hi all,
Unfortunately, my WD doesn't work anymore: 3 clicks at power on and then spin off.
Thanks to this forum I saw it may be a PCB problem and I found a matching one (2060-701335-003 REV B from a WD2000JS-00MHB0 DSBACTJCA).
As seen here, I swapped the U12 chip and no chance:
My drive with other U12 and other PCB: drive spins normally but is not recognised by BIOS
My drive with my U12 and other PCB: 3 clicks and spins off...
Other drive with other U12 and my PCB: works perfectly.
Conclusion is that my U12 is dead :(
Is there any way to recover my WD by finding a matching U12 ? Or to get one programmed for my drive ?
If yes, which of following information should match exactly ? (seems that it's DCM but not sure)
model information:
S/N: WMANK1299207
LBA: 488397168
MDL: WD2500JS-00MHB0
Date: 30 AUG 2005
DCM: DSBHCTJCA
Malaysia
PCB : 2060-701335-003 REV B
White sticker : 2061-701335-800 AG XW 2T19 5B3L 1 0007100 6107
Any help is welcome :)
Thanks,
Christophe
 Post subject: Re: WD2500JS-00MHB0 - U12 is dead
PostPosted: February 15th, 2011, 17:28
Wrong, conclusion is that there is nothing wrong with your PCB
PostPosted: February 15th, 2011, 17:37
griffe27:
Your drive have one (or more) dead head.
You need professional help, if you need your data back.
Janos
PostPosted: February 15th, 2011, 17:45
Thanks for your quick answers!
With other PCB and other U12, the drive spins normally (no click and no spin off), could it however be an hardware problem?
Is there a way to "check" my U12? (I prefer to be sure it's a head problem before spending a lot of money, between 400$ and 1200$ as I saw).
Thanks again,
Christophe
PostPosted: February 15th, 2011, 19:31
If your U12 would be dead, the PCB would not spin up the HDA.
PostPosted: February 16th, 2011, 2:11
Thanks for explanation !
Christophe
PostPosted: February 16th, 2011, 22:49
i can help you rebuild it. please email or SKYPE if need.
data recovery service[/b]
PostPosted: February 19th, 2011, 22:54
Hi, I have this working PCB in stock, pls contact my hotmail.
Thanks, Eric.
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
Users browsing this forum: No registered users and 52 guests
