 Post subject: FIRMWARE REQUEST
PostPosted: July 22nd, 2011, 3:47
Hello, i would like to request a firmware for a seagate hdd ST3320418AS.It's current firmware if CC45.I have searched in forums datadonor.net, firmwarebase.com and in hddguru forum.I use the hdd - doctor suite from salvation data.Thank you all in advance.
 Post subject: Re: FIRMWARE REQUEST
PostPosted: July 26th, 2011, 5:32
I don't have that firmware version (CC45), but may I ask you what's your drive problem and why you are requesting this formware?
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: July 26th, 2011, 6:59
Hi Luca,
I use HDDoctor from salvation data and my diagnosis is that i need to update the firmware.Well i hope that i am right but i won't know if i don't try :P
Do you have an another firmware version for this HDD?
PostPosted: July 26th, 2011, 7:57
upload the whole firmware?????? :shock:
What did you do to diagnose this drive and what's the problem, to upload all the modules is not a good option.
Do you need to recover data?
PostPosted: July 26th, 2011, 9:10
Hey
Yes i need to recover data.HDDoctor can't read some modules so i thought to update them.That's the thought.Any suggestion is welcome.Obviously i am new at this.
PostPosted: July 26th, 2011, 11:58
be very careful, if you overwite unique modules, you will not have data back!
Some modules can be overwritten and sometimes is not important to match firmware version, but if your problem involve i.e. translator modules you can't overwrite.
PostPosted: July 28th, 2011, 3:50
I agree with IRS. You must be very carefull what modules you overwrite or the customers data will be gone forever. Another module you won't want to overwrite is the P-list module or modules. I do not recommend experimenting with customer data. I own the Seagate Hard Drive Doctor and Suite also and it is limited what you can do firmware wise with a Barracuda 7200.12. The only option is to overwrite firmware modules and not the compare and repair option like some of the other HDD Doctors allow. Be sure to make a backup of the all firmware modules before attempting to overwrite any module. My motto for my data recovery service is to never make the problem worse. Especially with a customers hard drive. If I cannot detemine the cause of a problem or are not sure of the outcome, I don't attempt it with customers drives.
Alan
Users browsing this forum: No registered users and 30 guests
